Hello.
Does anyone knows if it is possible to restore the database of urbackup?
The server which urbackup was running on crashed an need to reinstall windows svr. Backup files from clients are OK in a different disk, but i need to know if just by reinstalling windows server and urbackup server, the backups will work as the day before the server crashed.
Thanks in advance
Yes … u can.
By Default urbackup backup’s its database also.
Access the storage repository, u will find a folder name “urbackup” thats the database folder.
On new server installation you shoud install UrB srv to the same disk letter… or…
During to move UrB instance, I have to run some SQL queries over database for change path,
about 20k rows…
