Hi.
I downloaded your must recent build urbackup-server_1.3.0.409.orig.tar.gz from
http://urpc.dyndns.org/urbackup_unstable/
I noticed some changes in the script /usr/local/sbin/start_urbackup_server so i didnt perform steps C and D of your guide Debugging with gdb on Linux
Now I get the following error when trying to start the server using start_urbackup_server --loglevel debug --no_daemon
2013-11-26 11:09:35: HTTP: Server started up sucessfully!
2013-11-26 11:09:35: Destroying all databases...
2013-11-26 11:09:35: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: disk I/O error
2013-11-26 11:09:35: ERROR: Error in CQuery::Execute - disk I/O error Stmt: [ATTACH DATABASE 'urbackup/backup_server_settings.db' AS settings_db]
2013-11-26 11:09:35: ERROR: SQL: disk I/O error Stmt: [ATTACH DATABASE 'urbackup/backup_server_settings.db' AS settings_db]
2013-11-26 11:09:35: Created new database connection for urbackup/backup_server.db
2013-11-26 11:09:35: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey='db_version']: disk I/O error
2013-11-26 11:09:35: Importing data...
2013-11-26 11:09:35: ERROR: Error preparing Query [PRAGMA journal_mode=WAL]: disk I/O error
2013-11-26 11:09:35: ERROR: Error preparing Query [SELECT value FROM settings_db.settings WHERE key='backupfolder' AND clientid=0]: disk I/O error
2013-11-26 11:09:35: ERROR: Error preparing Query [INSERT INTO settings_db.settings (key, value, clientid) VALUES ('backupfolder', ?, 0)]: disk I/O error
Segmentation fault (core dumped)
I am not sure whats the error. It says IO problem but the server was working perfectly when I tried to install the last version. Also, I couldnt find the new ulimit parameter in the start script.
uroni
November 26, 2013, 7:06pm
22
Okay. I changed the logic which finds the paths. Maybe it did not find the database at all. Is it in /usr/local/var/urbackup or /var/urbackup ?
Anyway: I changed to to exit gracefully now (while outputting where it expects the database).
You can run it in gdb with
start_urbackup_server --loglevel debug --run_in_gdb
now.
/var/urbackup/ contains lots of files.
backupfolder clientlist_36.ub clientlist_71.ub
backup_server.db clientlist_37.ub clientlist_72.ub
backup_server.db-shm clientlist_38.ub clientlist_73.ub
backup_server.db.template clientlist_39.ub clientlist_74.ub
backup_server.db-wal clientlist_3.ub clientlist_75.ub
backup_server_settings.db clientlist_40.ub clientlist_76.ub
backup_server_settings.db-shm clientlist_41.ub clientlist_77.ub
backup_server_settings.db-wal clientlist_42.ub clientlist_78.ub
clientlist_10.ub clientlist_44.ub clientlist_79.ub
clientlist_11.ub clientlist_45.ub clientlist_7.ub
clientlist_17.ub clientlist_51.ub clientlist_86.ub
clientlist_18.ub clientlist_52.ub clientlist_87.ub
clientlist_19.ub clientlist_53.ub clientlist_88.ub
clientlist_1_new.ub clientlist_54.ub clientlist_89.ub
clientlist_1.ub clientlist_55.ub clientlist_8.ub
clientlist_20.ub clientlist_56.ub clientlist_90.ub
clientlist_21.ub clientlist_57.ub clientlist_91.ub
clientlist_22.ub clientlist_58.ub clientlist_92.ub
clientlist_23.ub clientlist_59.ub clientlist_93.ub
clientlist_24.ub clientlist_5.ub clientlist_94_new.ub
clientlist_25.ub clientlist_60.ub clientlist_94.ub
clientlist_26.ub clientlist_61.ub clientlist_95.ub
clientlist_27.ub clientlist_62.ub clientlist_9.ub
clientlist_28.ub clientlist_63.ub fontList.cache
clientlist_29.ub clientlist_64.ub google_chart.js
clientlist_2.ub clientlist_65.ub server_ident.key
clientlist_30.ub clientlist_66.ub server_token.key
clientlist_31.ub clientlist_67.ub status.htm
clientlist_32.ub clientlist_68_new.ub tex.cache
clientlist_33.ub clientlist_68.ub UrBackupUpdate.exe
clientlist_34.ub clientlist_69.ub UrBackupUpdate.sig
clientlist_35_new.ub clientlist_6.ub version.txt
clientlist_35.ub clientlist_70.ub www
/usr/local/var/urbackup/ contains only a few
backup_server.db.template google_chart.js status.htmurbackup_dsa.pub www
Do I need to download a new build?
Thx.
I ran start_urbackup_server --loglevel debug --run_in_gdb and got
Starting program: /usr/local/sbin/urbackup_srv --plugin /usr/local/lib/liburbackupserver_urlplugin.so --plugin /usr/local/lib/liburbackupserver_cryptoplugin.so --plugin /usr/local/lib/liburbackupserver_downloadplugin.so --plugin /usr/local/lib/liburbackupserver_fsimageplugin.so --plugin /usr/local/lib/liburbackupserver_httpserver.so --plugin /usr/local/lib/liburbackupserver.so --http_root /var/urbackup/www --workingdir /var --user urbackup --snapshot_helper /usr/local/bin/urbackup_snapshot_helper --port 55413 --logfile /var/log/urbackup.log --loglevel debug --http_port 55414 --pidfile /var/run/urbackup_srv.pid
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/i386-linux-gnu/libthread_db.so.1".
2013-11-26 14:14:20: Changing user...
2013-11-26 14:14:20: done.
2013-11-26 14:14:20: Loaded -url- plugin
2013-11-26 14:14:21: Loaded -cryptoplugin- plugin
2013-11-26 14:14:21: Loaded -download- plugin
2013-11-26 14:14:21: Loaded -fsimageplugin- plugin
2013-11-26 14:14:21: Starting HTTP-Server on port 55414
2013-11-26 14:14:21: HTTP: Server started up sucessfully!
[New Thread 0xb7058b40 (LWP 12022)]
2013-11-26 14:14:21: Destroying all databases...
2013-11-26 14:14:21: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: disk I/O error
2013-11-26 14:14:21: ERROR: Error in CQuery::Execute - disk I/O error Stmt: [ATTACH DATABASE 'urbackup/backup_server_settings.db' AS settings_db]
2013-11-26 14:14:21: ERROR: SQL: disk I/O error Stmt: [ATTACH DATABASE 'urbackup/backup_server_settings.db' AS settings_db]
2013-11-26 14:14:21: Created new database connection for urbackup/backup_server.db
2013-11-26 14:14:21: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey='db_version']: disk I/O error
2013-11-26 14:14:21: Importing data...
2013-11-26 14:14:21: ERROR: Error preparing Query [PRAGMA journal_mode=WAL]: disk I/O error
2013-11-26 14:14:21: ERROR: Error preparing Query [SELECT value FROM settings_db.settings WHERE key='backupfolder' AND clientid=0]: disk I/O error
2013-11-26 14:14:21: ERROR: Error preparing Query [INSERT INTO settings_db.settings (key, value, clientid) VALUES ('backupfolder', ?, 0)]: disk I/O error
Program received signal SIGSEGV, Segmentation fault.
0xb66d2631 in LoadActions (pServer=0x81455a0) at dllmain.cpp:413
413q->Bind(trim(bf));
#0 0xb66d2631 in LoadActions (pServer=0x81455a0) at dllmain.cpp:413
#1 0x0806ca35 in CServer::LoadDLL (this=0x81332e0, name=...)
at ServerLinux.cpp:50
#2 0x0807a06f in main_fkt (argc=31, argv=0xbffff554) at main.cpp:413
#3 0x08050c2b in main (argc=31, argv=0xbffff554) at main.cpp:106
uroni
November 26, 2013, 9:11pm
25
Can you use this one: http://urpc.dyndns.org/urbackup_unstable/urbackup-server-1.3.0.410.tar.gz
Can you also check the permissions, please. The user “urbackup” should own the whole /var/urbackup folder.
ok. Ill compile now and let you know in about 10mins.
But the permissions part, is it something new?
It seems permissions are right
drwxr-xr-x 4 urbackup urbackup 4096 Nov 26 16:14 urbackup
Compiling new version right now.
Compiled the new version and having the same error
2013-11-26 16:22:31: Changing user...
2013-11-26 16:22:31: done.
2013-11-26 16:22:31: Loaded -url- plugin
2013-11-26 16:22:32: Loaded -cryptoplugin- plugin
2013-11-26 16:22:32: Loaded -download- plugin
2013-11-26 16:22:32: Loaded -fsimageplugin- plugin
2013-11-26 16:22:32: Starting HTTP-Server on port 55414
2013-11-26 16:22:32: HTTP: Server started up sucessfully!
[New Thread 0xb7058b40 (LWP 3280)]
2013-11-26 16:22:32: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: disk I/O error
2013-11-26 16:22:32: Created new database connection for urbackup/backup_server.db
2013-11-26 16:22:32: Destroying all databases...
2013-11-26 16:22:32: ERROR: Error in CQuery::Execute - disk I/O error Stmt: [ATTACH DATABASE 'urbackup/backup_server_settings.db' AS settings_db]
2013-11-26 16:22:32: ERROR: SQL: disk I/O error Stmt: [ATTACH DATABASE 'urbackup/backup_server_settings.db' AS settings_db]
2013-11-26 16:22:32: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey='db_version']: disk I/O error
2013-11-26 16:22:32: Importing data...
2013-11-26 16:22:32: ERROR: Error preparing Query [PRAGMA journal_mode=WAL]: disk I/O error
2013-11-26 16:22:32: ERROR: Error preparing Query [SELECT value FROM settings_db.settings WHERE key='backupfolder' AND clientid=0]: disk I/O error
2013-11-26 16:22:32: ERROR: Error preparing Query [INSERT INTO settings_db.settings (key, value, clientid) VALUES ('backupfolder', ?, 0)]: disk I/O error
0xb6dd04e1 in LoadActions (pServer=0x8145110) at dllmain.cpp:429
429q->Bind(trim(bf));
Just in case
root@urbuntu:/var/urbackup# ls -l
total 5025260
-rw-r--r-- 1 root root 23 Oct 22 11:17 backupfolder
-rwxr-x--- 1 urbackup urbackup 3277377536 Nov 26 10:50 backup_server.db
-rwxr-x--- 1 urbackup urbackup 0 Nov 26 16:22 backup_server.db-shm
-rw-r--r-- 1 urbackup urbackup 22528 Aug 29 18:01 backup_server.db.template
-rwxr-x--- 1 urbackup urbackup 1753422456 Nov 26 10:50 backup_server.db-wal
-rw-r--r-- 1 urbackup urbackup 17408 Nov 20 11:51 backup_server_settings.db
-rw-r--r-- 1 urbackup urbackup 32768 Nov 25 08:36 backup_server_settings.db-shm
-rw-r--r-- 1 urbackup urbackup 1048032 Nov 21 18:04 backup_server_settings.db-wal
-rwxr-x--- 1 urbackup urbackup 25781 Nov 22 09:47 clientlist_10.ub
-rwxr-x--- 1 urbackup urbackup 289255 Nov 22 08:21 clientlist_11.ub
-rwxrwx--- 1 urbackup urbackup 682499 Nov 18 09:43 clientlist_12.ub
-rwxr-x--- 1 urbackup urbackup 110799 Nov 22 12:20 clientlist_13.ub
-rwxr-x--- 1 urbackup urbackup 518067 Nov 20 09:20 clientlist_14.ub
-rwxr-x--- 1 urbackup urbackup 422851 Nov 22 08:30 clientlist_15.ub
-rwxr-x--- 1 urbackup urbackup 390504 Nov 22 13:08 clientlist_16.ub
-rwxr-x--- 1 urbackup urbackup 0 Nov 26 10:50 clientlist_17_new.ub
-rwxr-x--- 1 urbackup urbackup 597103 Nov 22 13:09 clientlist_17.ub
-rwxrwx--- 1 urbackup urbackup 33482 Oct 29 08:19 clientlist_18.ub
-rwxr-x--- 1 urbackup urbackup 101655 Nov 20 12:04 clientlist_19.ub
-rwxrwx--- 1 urbackup urbackup 5699 Oct 28 08:24 clientlist_1_new.ub
-rwxrwx--- 1 urbackup urbackup 33253 Oct 23 20:59 clientlist_1.ub
-rwxr-x--- 1 urbackup urbackup 297402 Nov 21 17:29 clientlist_20.ub
-rwxr-x--- 1 urbackup urbackup 105047 Nov 21 17:32 clientlist_21.ub
-rwxrwx--- 1 urbackup urbackup 193676 Nov 18 09:05 clientlist_22.ub
-rwxr-x--- 1 urbackup urbackup 609287 Nov 22 18:01 clientlist_23.ub
-rwxr-x--- 1 urbackup urbackup 3665888 Nov 5 12:26 clientlist_24.ub
-rwxr-x--- 1 urbackup urbackup 864241 Nov 21 00:13 clientlist_25.ub
-rwxr-x--- 1 urbackup urbackup 1135730 Nov 22 14:01 clientlist_26.ub
-rwxr-x--- 1 urbackup urbackup 47893 Nov 22 17:43 clientlist_27.ub
-rwxr-x--- 1 urbackup urbackup 288407 Nov 21 18:40 clientlist_28.ub
-rwxr-x--- 1 urbackup urbackup 64742 Nov 20 08:59 clientlist_29.ub
-rwxr-x--- 1 urbackup urbackup 54027 Nov 25 08:55 clientlist_2.ub
-rwxr-x--- 1 urbackup urbackup 1638 Nov 20 14:15 clientlist_30.ub
-rwxr-x--- 1 urbackup urbackup 1346280 Nov 22 19:27 clientlist_31.ub
-rwxr-x--- 1 urbackup urbackup 3896399 Nov 25 12:14 clientlist_32.ub
-rwxr-x--- 1 urbackup urbackup 1473476 Nov 22 18:47 clientlist_33.ub
-rwxr-x--- 1 urbackup urbackup 1293189 Nov 22 19:30 clientlist_34.ub
-rwxr-x--- 1 urbackup urbackup 81920 Nov 26 10:50 clientlist_35_new.ub
-rwxrwx--- 1 urbackup urbackup 212047 Nov 18 09:05 clientlist_35.ub
-rwxr-x--- 1 urbackup urbackup 440920 Nov 5 16:52 clientlist_36.ub
-rwxr-x--- 1 urbackup urbackup 166550 Nov 22 12:57 clientlist_37.ub
-rwxrwx--- 1 urbackup urbackup 869369 Nov 4 16:27 clientlist_38.ub
-rwxr-x--- 1 urbackup urbackup 341740 Nov 22 09:38 clientlist_39.ub
-rwxr-x--- 1 urbackup urbackup 1530 Nov 23 21:16 clientlist_3.ub
-rwxrwx--- 1 urbackup urbackup 1852 Nov 15 12:13 clientlist_40.ub
-rwxr-x--- 1 urbackup urbackup 266809 Nov 22 13:15 clientlist_41.ub
-rwxr-x--- 1 urbackup urbackup 126214 Nov 25 08:58 clientlist_42.ub
-rwxr-x--- 1 urbackup urbackup 13386 Nov 23 14:13 clientlist_44.ub
-rwxr-x--- 1 urbackup urbackup 911366 Nov 22 11:24 clientlist_45.ub
-rwxr-x--- 1 urbackup urbackup 21233 Nov 21 19:04 clientlist_46.ub
-rwxr-x--- 1 urbackup urbackup 1873450 Nov 21 18:51 clientlist_47.ub
-rwxr-x--- 1 urbackup urbackup 4673116 Nov 25 13:01 clientlist_48.ub
-rwxr-x--- 1 urbackup urbackup 111975 Nov 22 11:18 clientlist_49.ub
-rwxrwx--- 1 urbackup urbackup 64557 Nov 1 18:31 clientlist_4.ub
-rwxrwx--- 1 urbackup urbackup 47652 Nov 18 09:06 clientlist_50.ub
-rwxr-x--- 1 urbackup urbackup 65298 Nov 5 09:36 clientlist_51.ub
-rwxrwx--- 1 urbackup urbackup 516366 Nov 5 07:00 clientlist_52.ub
-rwxr-x--- 1 urbackup urbackup 9676 Nov 21 13:26 clientlist_53.ub
-rwxr-x--- 1 urbackup urbackup 26023 Nov 20 11:52 clientlist_54.ub
-rwxr-x--- 1 urbackup urbackup 331287 Nov 5 19:28 clientlist_55.ub
-rwxr-x--- 1 urbackup urbackup 430372 Nov 20 17:41 clientlist_56.ub
-rwxr-x--- 1 urbackup urbackup 675084 Nov 22 09:31 clientlist_57.ub
-rwxrwx--- 1 urbackup urbackup 134008 Nov 18 12:11 clientlist_58.ub
-rwxr-x--- 1 urbackup urbackup 50532 Nov 25 08:56 clientlist_59.ub
-rwxr-x--- 1 urbackup urbackup 1236384 Nov 23 21:03 clientlist_5.ub
-rwxr-x--- 1 urbackup urbackup 2975712 Nov 21 20:06 clientlist_60.ub
-rwxr-x--- 1 urbackup urbackup 981 Nov 23 21:26 clientlist_61.ub
-rwxr-x--- 1 urbackup urbackup 86297 Nov 22 18:17 clientlist_62.ub
-rwxr-x--- 1 urbackup urbackup 471530 Nov 22 12:21 clientlist_63.ub
-rwxr-x--- 1 urbackup urbackup 30626 Nov 22 11:37 clientlist_64.ub
-rwxr-x--- 1 urbackup urbackup 111043 Nov 22 09:52 clientlist_65.ub
-rwxr-x--- 1 urbackup urbackup 606543 Nov 21 14:21 clientlist_66.ub
-rwxr-x--- 1 urbackup urbackup 2513514 Nov 22 17:42 clientlist_67.ub
-rwxr-x--- 1 urbackup urbackup 2658304 Nov 26 10:50 clientlist_68_new.ub
-rwxr-x--- 1 urbackup urbackup 101026 Nov 22 15:51 clientlist_68.ub
-rwxr-x--- 1 urbackup urbackup 2912682 Nov 20 10:27 clientlist_69.ub
-rwxr-x--- 1 urbackup urbackup 56110 Nov 25 12:03 clientlist_6.ub
-rwxr-x--- 1 urbackup urbackup 413675 Nov 22 13:02 clientlist_70.ub
-rwxrwx--- 1 urbackup urbackup 405066 Oct 28 13:50 clientlist_71.ub
-rwxr-x--- 1 urbackup urbackup 62747 Nov 20 13:59 clientlist_72.ub
-rwxr-x--- 1 urbackup urbackup 287128 Nov 25 09:05 clientlist_73.ub
-rwxr-x--- 1 urbackup urbackup 280474 Nov 25 12:44 clientlist_74.ub
-rwxr-x--- 1 urbackup urbackup 322134 Nov 22 19:17 clientlist_75.ub
-rwxr-x--- 1 urbackup urbackup 972247 Nov 21 20:13 clientlist_76.ub
-rwxr-x--- 1 urbackup urbackup 1993463 Nov 22 17:11 clientlist_77.ub
-rwxrwx--- 1 urbackup urbackup 485328 Nov 19 09:09 clientlist_78.ub
-rwxr-x--- 1 urbackup urbackup 682876 Nov 22 08:16 clientlist_79.ub
-rwxrwx--- 1 urbackup urbackup 135018 Oct 29 08:29 clientlist_7.ub
-rwxr-x--- 1 urbackup urbackup 882 Oct 29 15:57 clientlist_80.ub
-rwxr-x--- 1 urbackup urbackup 537236 Nov 21 23:16 clientlist_81.ub
-rwxr-x--- 1 urbackup urbackup 516728 Nov 21 20:48 clientlist_82.ub
-rwxr-x--- 1 urbackup urbackup 14332295 Nov 24 01:07 clientlist_83.ub
-rwxr-x--- 1 urbackup urbackup 176048 Nov 22 17:30 clientlist_84.ub
-rwxr-x--- 1 urbackup urbackup 878155 Nov 20 14:00 clientlist_85.ub
-rwxr-x--- 1 urbackup urbackup 381288 Nov 22 10:48 clientlist_86.ub
-rwxr-x--- 1 urbackup urbackup 1326476 Nov 20 10:07 clientlist_87.ub
-rwxr-x--- 1 urbackup urbackup 2943467 Nov 21 01:00 clientlist_88.ub
-rwxr-x--- 1 urbackup urbackup 673833 Nov 22 11:28 clientlist_89.ub
-rwxr-x--- 1 urbackup urbackup 6269304 Nov 21 20:22 clientlist_8.ub
-rwxr-x--- 1 urbackup urbackup 771120 Nov 20 09:18 clientlist_90.ub
-rwxr-x--- 1 urbackup urbackup 7353514 Nov 22 12:45 clientlist_91.ub
-rwxr-x--- 1 urbackup urbackup 194419 Nov 25 11:35 clientlist_92.ub
-rwxr-x--- 1 urbackup urbackup 3676478 Nov 25 09:06 clientlist_93.ub
-rwxr-x--- 1 urbackup urbackup 0 Nov 26 10:50 clientlist_94_new.ub
-rwxr-x--- 1 urbackup urbackup 54253 Nov 22 11:18 clientlist_94.ub
-rwxr-x--- 1 urbackup urbackup 2929729 Nov 22 16:20 clientlist_95.ub
-rwxr-x--- 1 urbackup urbackup 559030 Nov 21 14:17 clientlist_9.ub
-rw-r--r-- 1 urbackup urbackup 19461 Oct 22 11:17 fontList.cache
-rw-r--r-- 1 urbackup urbackup 60 Aug 29 18:01 google_chart.js
-rw-r--r-- 1 urbackup urbackup 23 Oct 22 11:17 server_ident.key
-rw-r--r-- 1 urbackup urbackup 20 Oct 22 11:17 server_token.key
-rw-r--r-- 1 urbackup urbackup 1572 Aug 29 18:01 status.htm
drwxr-xr-x 2 urbackup urbackup 4096 Oct 22 11:17 tex.cache
-rw-r--r-- 1 root root 4794845 Nov 26 15:13 urbackup-server_1.3.0.410.orig.tar.gz
-rw-r--r-- 1 urbackup urbackup 14290534 Oct 22 11:19 UrBackupUpdate.exe
-rw-r--r-- 1 urbackup urbackup 40 Oct 22 11:18 UrBackupUpdate.sig
-rw-r--r-- 1 urbackup urbackup 2 Oct 22 11:19 version.txt
drwxr-xr-x 2 urbackup urbackup 4096 Oct 22 11:16 www
Hi.
I am having the same issues with urbackup-server_1.3.0.411.orig.tar.gz
uroni
November 27, 2013, 6:10pm
31
Hi.
Our Xen server crashed during the weekend, now I am trying to start the server and I get the following error. Any idea?
root@urbuntu:~# start_urbackup_server --loglevel debug --run_in_gdb
GNU gdb (Ubuntu/Linaro 7.4-2012.04-0ubuntu2.1) 7.4-2012.04
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "i686-linux-gnu".
For bug reporting instructions, please see:
<http://bugs.launchpad.net/gdb-linaro/>...
Reading symbols from /usr/local/sbin/urbackup_srv...done.
(gdb) run
2013-12-02 09:07:37: Changing user...
2013-12-02 09:07:37: done.
2013-12-02 09:07:37: Loaded -url- plugin
2013-12-02 09:07:38: Loaded -cryptoplugin- plugin
2013-12-02 09:07:38: Loaded -download- plugin
2013-12-02 09:07:38: Loaded -fsimageplugin- plugin
2013-12-02 09:07:38: Starting HTTP-Server on port 55414
2013-12-02 09:07:38: ERROR: HTTP: Failed binding SOCKET to Port 55414
[New Thread 0xb7058b40 (LWP 3033)]
[Thread 0xb7058b40 (LWP 3033) exited]
2013-12-02 09:07:39: Created new database connection for urbackup/backup_server.db
2013-12-02 09:07:39: Destroying all databases...
2013-12-02 09:07:39: Creating files Indices...
2013-12-02 09:07:39: Started UrBackup...
2013-12-02 09:07:39: Error loading IPychartFactory
[New Thread 0xb7058b40 (LWP 3034)]
2013-12-02 09:07:39: Removing temporary files...
2013-12-02 09:07:39: Recreating temporary folder...
2013-12-02 09:07:39: Testing if backup destination can handle subvolumes and snapshots...
sh: 1: /sbin/btrfs: not found
chown: cannot access `/media/BACKUP/urbackup/testA54hj5luZtlorr494/A': No such file or directory
Creating test subvolume failed
2013-12-02 09:07:39: Backup destination cannot handle subvolumes and snapshots. Snapshots disabled.
2013-12-02 09:07:39: Binding to interface eth0 for broadcasting...
[New Thread 0xb6bffb40 (LWP 3041)]
[New Thread 0xb6afeb40 (LWP 3042)]
2013-12-02 09:07:39: UrBackup Server start up complete.
[New Thread 0xb65ffb40 (LWP 3043)]
2013-12-02 09:07:39: Creating SOCKET...
2013-12-02 09:07:39: done.
2013-12-02 09:07:39: Looking for old Sessions... 0 sessions
2013-12-02 09:07:39: ERROR: Failed binding SOCKET to Port 55413
2013-12-02 09:07:39: ERROR: Error while starting listening to ports. Stopping server.
2013-12-02 09:07:39: Exited Loop
2013-12-02 09:07:39: Deleting at..
2013-12-02 09:07:39: Deleting SelectThreads..
2013-12-02 09:07:39: Deleting lbs...
2013-12-02 09:07:39: Shutting down plugins...
2013-12-02 09:07:40: Deleting server...
[Thread 0xb65ffb40 (LWP 3043) exited]
[Thread 0xb6afeb40 (LWP 3042) exited]
[Thread 0xb7058b40 (LWP 3034) exited]
[Thread 0xb7cd3700 (LWP 3030) exited]
[Inferior 1 (process 3030) exited normally]
(gdb) bt
No stack.
uroni
December 2, 2013, 3:48pm
33
Some other process is blocking port 55413. Probably another server instance. You can see what is listening on which socket via “lsof”.
Hi.
Crashed again with the following
Program received signal SIGHUP, Hangup.
0xb7fdd424 in __kernel_vsyscall ()
(gdb) bt
#0 0xb7fdd424 in __kernel_vsyscall ()
#1 0xb7de2460 in poll () from /lib/i386-linux-gnu/libc.so.6
#2 0x08052179 in CAcceptThread::operator() (this=0x81628c0, single=true)
at AcceptThread.cpp:153
#3 0x0807a470 in main_fkt (argc=31, argv=0xbffff554) at main.cpp:460
#4 0x08050ceb in main (argc=31, argv=0xbffff554) at main.cpp:106
(gdb)
uroni
December 3, 2013, 10:15pm
36
Thats the log rotation. Enter “handle SIGHUP nostop” in gdb to prevent that.
Hi.
In Debugging with gdb on Linux you wrote
[quote=""]With UrBackup Server >= 1.3:
Run the UrBackup server via
start_urbackup_server --loglevel debug --start_in_gdb
If you want to log off while it runs, run it in screen[/quote]
but for me, start_urbackup_server --loglevel debug --run_in_gdb works. Maybe a misspell?
Hi.
I am having a problem with big folders (big folders with thousand of small files), about 30G and 50G.
The server seems just to be ignoring them. It is making a daily differential backup of the machine but these folders are no where, not even empty.
Any way to force the server to backup those files?
Thanks.
Enrique.
uroni
December 16, 2013, 11:15pm
40
If they aren’t backed up it is not intentional.
Can you take a look at the C:\Program Files\UrBackup\urbackup\data\filelist.ub files to see if the files are correctly in there?
Are there any errors in the logs?
How are your include/exclude settings and the backup paths?
Which file system are you using on the server?
I just tested with 65536 files and it seemed to work. Are your files directly in a backup path or a subfolder?
