Thanks for the reply,
I already done these step but no luck.
please find the error log.
urbackup-client-nogui-1.4.6-13.1.x86_64 from home_kot1grun has depsolving problems
–> Missing Dependency: systemd is needed by package urbackup-client-nogui-1.4.6-13.1.x86_64 (home_kot1grun)
cryptopp-5.6.2-12.1.x86_64 from home_kot1grun has depsolving problems
–> Missing Dependency: libstdc++.so.6(GLIBCXX_3.4.15)(64bit) is needed by package cryptopp-5.6.2-12.1.x86_64 (home_kot1grun)
Error: Missing Dependency: libstdc++.so.6(GLIBCXX_3.4.9)(64bit) is needed by package cryptopp-5.6.2-12.1.x86_64 (home_kot1grun)
Error: Missing Dependency: systemd is needed by package urbackup-client-nogui-1.4.6-13.1.x86_64 (home_kot1grun)
Error: Missing Dependency: libstdc++.so.6(GLIBCXX_3.4.15)(64bit) is needed by package cryptopp-5.6.2-12.1.x86_64 (home_kot1grun)
Error: Missing Dependency: libc.so.6(GLIBC_2.14)(64bit) is needed by package urbackup-client-nogui-1.4.6-13.1.x86_64 (home_kot1grun)
Error: Missing Dependency: libstdc++.so.6(GLIBCXX_3.4.11)(64bit) is needed by package urbackup-client-nogui-1.4.6-13.1.x86_64 (home_kot1grun)
Error: Missing Dependency: libstdc++.so.6(GLIBCXX_3.4.9)(64bit) is needed by package urbackup-client-nogui-1.4.6-13.1.x86_64 (home_kot1grun)
Error: Missing Dependency: libc.so.6(GLIBC_2.15)(64bit) is needed by package cryptopp-5.6.2-12.1.x86_64 (home_kot1grun)
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
The program package-cleanup is found in the yum-utils package.
[root@lg-srvr-1 urbackup]# cat /etc/redhat-release
Red Hat Enterprise Linux Server release 5.11 (Tikanga)
[root@lg-srvr-1 urbackup]# yum repolist
Loaded plugins: dellsysid, product-id, security, subscription-manager
repo id repo name status
dell-omsa-indep Dell OMSA repository - Hardware independent 2,991
dell-omsa-specific Dell OMSA repository - Hardware specific 12
home_kot1grun kot1grun’s Home Project (RHEL_7) 12
rhel-5-server-cf-tools-1-rpms Red Hat CloudForms Tools for RHEL 5 (RPMs) 35
rhel-5-server-rpms Red Hat Enterprise Linux 5 Server (RPMs) 16,631
rhel-server-dts-5-rpms Red Hat Developer Toolset RPMs for Red Hat Enterprise Linux 5 Server 84
rhel-server-dts2-5-rpms Red Hat Developer Toolset 2 RPMs for Red Hat Enterprise Linux 5 Server 163
repolist: 19,928
So, you try to use packages for RHEL 7 on RHEL 5. It is not possible. Try package for RHEL 6, but I can’t guarantee it will work. I’ll try to build client for RHEL 5 and publish elsewhere as OBS does not support this distrib version.
I tried RHEL 6, as well that one also not working. Please let me know if build for RHEL 5, or any other way to install urbackup client installation on RHEL 5. Let me know.
