Heya,
I recently updated to UrBackup 2.5.27 and had a lot of problems ever since.
How I got there:
- Updated UrBackup docker on Unraid to lastest version.
- Added new client to UrBackup server webUI, then downloaded the appropiate client installer.
- Everything works fine.
- I restart my pc while the file backup is not fully done. (would have taken 3 more hours and I wanted to go to bed
- Start my PC again. Sais that the client has seen the server since after I booted it, going up so having no further connection.
- I try to restart the server docker instance to maybe resolve the issue.
- The webUI sais that the client is online but the identifier has changed.
- I accept the new Identifier. ( never had such problem before)
- After that, the client is red, saying it cannot connect to the server plus runs on litterally 1fps if not even less. By that I mean when I try to click the icon in the bottom right corner, it takes 2 seconds to even open the right click menu. And navigating that menu has also a delay of 2 seconds. And my PC is running just fine.
- If I left click the UrBackup client, I get an error message that sais: “There was an error. Currently nothing can be backed up.”
- The last log entries in the client are the following:
2022-11-29 11:15:35: ERROR: Could not open path in os_get_final_path for "E:\Programmieren\Directus\load-tester\node_modules\.pnpm\@esbuild-kit+cjs-loader@2.3.3\node_modules\@esbuild-kit\cjs-loader\"
2022-11-29 11:15:35: ERROR: Could not open path in os_get_final_path for "E:\Programmieren\Directus\load-tester\node_modules\.pnpm\@esbuild-kit+esm-loader@2.4.2\node_modules\@esbuild-kit\esm-loader\"
2022-11-29 11:15:35: ERROR: Could not open path in os_get_final_path for "E:\Programmieren\Directus\load-tester\node_modules\.pnpm\@directus+sdk@10.1.4\node_modules\@directus\sdk\"
2022-11-29 11:15:35: ERROR: Could not open path in os_get_final_path for "E:\Programmieren\node_modules\.pnpm\arcsecond@4.1.0\node_modules\arcsecond\"
2022-11-29 11:15:35: ERROR: Could not open path in os_get_final_path for "E:\Programmieren\node_modules\.pnpm\@types+node@16.11.48\node_modules\@types\node\"
2022-11-29 11:15:35: WARNING: SQLite: too many SQL variables in "DELETE FROM files WHERE (tgroup=0 OR tgroup=?) AND (name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB errorcode: 1
2022-11-29 11:15:35: ERROR: Error preparing Query [DELETE FROM files WHERE (tgroup=0 OR tgroup=?) AND (name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ? OR name GLOB ?)]: too many SQL variables
2022-11-29 11:15:35: ERROR: Fatal exception code 3221225477 at address 0x00007FFF8D67039A
2022-11-29 11:15:37: ERROR: Fatal exception (APPLICATION CRASHED). Crash dump written to "C:\Windows\TEMP\UrBackup\v2.0.0-20221129-111535-17836-9228.dmp"
2022-11-29 11:15:37: ERROR: Program abort (SIGABRT)
I had to remove a lot of these GLOB parts as the message was to long.
Another thing is that I tried to exclude all node_module folders from being backed up by putting them on the blacklist in the server like so: " *\node_modules* ". Could it be that the client doesn’t recieve these settings as they are stored in the server, still attempts to read the folders and then crashes?
Server version: 2.5.27 Docker on Unraid
Client version: 2.5.21 on Windows.
Any help would be greatly appreciated. I will try to answer to any questions here asap!
