UrBackup Client 2.5.29.pkg
Hello world,
the last Mac package 2.5.29 doesn’t provide arch for my iMac Intel x64.
/Applications/UrBackup Client.app/Contents/MacOS/sbin/urbackupclientbackend: Bad CPU type in executable
% file “/Applications/UrBackup Client.app/Contents/MacOS/sbin/urbackupclientbackend”
/Applications/UrBackup Client.app/Contents/MacOS/sbin/urbackupclientbackend: Mach-O 64-bit executable arm64
I’ll build from the source tree.
Are the other binaries in the package the same?
no, just the clientbackend. But nothing works without it :wink:
% file /Applications/UrBackup\ Client.app/Contents/MacOS/urbackupclientgui
/Applications/UrBackup Client.app/Contents/MacOS/urbackupclientgui: Mach-O universal binary with 2 architectures: [x86_64:Mach-O 64-bit executable x86_64] [arm64]
/Applications/UrBackup Client.app/Contents/MacOS/urbackupclientgui (for architecture x86_64):	Mach-O 64-bit executable x86_64
/Applications/UrBackup Client.app/Contents/MacOS/urbackupclientgui (for architecture arm64):	Mach-O 64-bit executable arm64
I think I may be having the same issue with my Intel MacBook. the latest 2.5.29 doesn’t work after installing.
