Hey,
I like to use Urbackup with Stablebit Drivepool has anybody used this together?
Drivepool could not use Hardlinks could I disable the use of Hardlinks on the Urbackup server?
Best Regards
Stefan
Hey,
Best Regards
Stefan
I used UrBackup on Drivepool, and is was painfully show, seemed to stop, and seemed to stop Drivepool from duplicating and checking.
I know use a UrBackup folder outside the Drivepool and it seems to work fine.
Deleting the old Urback folder in the Pool takes a very long time though.
