When I try to Install UrBackup Server 2.1.19 in Windows Server 2008, UrBackup stops working.
If I install and use version 1.4.11 (only works this version) it works.
I try to install UrBackup server 2.2.2 beta, but it stop working too, but gives me an error for Visual Studio 2015. Somebody knows?
Thanks.
When I install Visual Studio 2015 Update 3 in Windows Server 2008 (x86)
Descripción:
Stopped working
Firma con problemas:
Nombre del evento de problema: APPCRASH
Application Name: SetupLauncher.exe
Application Version: 14.0.25420.1
Application Timestamp: 576851fa
Fault Module Name: KERNEL32.dll
Fault Module Version: 6.0.6001.18631
Fault Module Timestamp: 4da467f0
Exception Code: e0434f4d
Exception Offset: 00044503
Versión del sistema operativo: 6.0.6001.2.1.0.274.10
Id. de configuración regional: 3082
Lea nuestra declaración de privacidad:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0c0a
If I install this package: https://www.microsoft.com/en-us/download/details.aspx?id=49050
(The update does not apply to the system)
You tried to install the server with both installers ?
UrBackup Server 2.1.19 (x86/x64) (Vista/7/8.1/10 + Server editions)
UrBackup Server 2.1.19 (x64) (Vista/7/8.1/10 + Server editions) MSI installer Only for up-to-date Windows
Is a Windows Server 2008 x86, I can’t install x64
