So, I am using the built package from the kot1grun repository:
I have downloaded the file like so (straight from the website):
cd /etc/yum.repos.d/
wget http://download.opensuse.org/repositories/home:kot1grun/CentOS_6/home:kot1grun.repo
yum install urbackup-client-nogui
However, the output from the final line comes out to this:
[root@CentOS yum.repos.d]# yum install urbackup-client-nogui
Loaded plugins: fastestmirror, priorities, refresh-packagekit
Setting up Install Process
Loading mirror speeds from cached hostfile
* base: pubmirrors.dal.corespace.com
* extras: mirror.compevo.com
* rpmforge: mirror.us.leaseweb.net
* updates: dallas.tx.mirror.xygenhosting.com
Resolving Dependencies
--> Running transaction check
---> Package urbackup-client-nogui.x86_64 0:1.4.9-3.1 will be installed
--> Processing Dependency: cryptopp for package: urbackup-client-nogui-1.4.9-3.1.x86_64
--> Processing Dependency: libcryptopp.so.6()(64bit) for package: urbackup-client-nogui-1.4.9-3.1.x86_64
---> Package cryptopp.x86_64 0:5.5.2-1.el6.rf will be installed
--> Finished Dependency Resolution
Error: Package: urbackup-client-nogui-1.4.9-3.1.x86_64 (home_kot1grun)
Requires: libcryptopp.so.6()(64bit)
You could try using --skip-broken to work around the problem
** Found 1 pre-existing rpmdb problem(s), 'yum check' output follows:
db4-4.7.25-20.el6_7.x86_64 is a duplicate with db4-4.7.25-17.el6.x86_64
When I try to run this:
[root@CentOS yum.repos.d]# yum install urbackup-client-nogui --skip-broken
It acts as if it completed, but I have no idea where to go to start the client - as it has still yet to populate the UrBackup server. It honestly would not be as bad if either the download site or the wiki had something for a CentOS installation; however, I found nothing on the download site and the Wiki only makes mention to Ubuntu and Debian - and I have tried some of the commands that are supposedly compatible, but it either gets to a part where the commands will no longer work and all the progress up was in vain, or it just errors out an I spend another fifty minutes browsing the web to find some string to follow… which normally leads to a dead-end.
My question, after all that ranting, is there someone who has some documentation on how to do it for a CentOS machine or at least knows where I can find the file - or what the name changes to because the “find” command was about as helpful as searching online.
If there is another way to do it, I am all eyes and ears for it.
If you needs exactly what I am running:
Linux version 2.6.32-279.2.1.e16.x86_64 (mockbuild@c6b7.bsys.dev.centos.org) (gcc version 4.4.6 20120305 (Red Hat 4.4.6-4) (GCC) ) #1 SMP Friday Jul 20 01:55:29 UTC 2012
CentOS release 6.7 (Final)
LSB_VERSION=base-4.0-amd64:base-4.0-noarch:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:print-4.0-noarch
