Dear Uroni ,
I have here a Server with a bit more users (50) . The database is right now 4945MB big . And it is very very slow via the webinterface.
I wanted to run a database vacuum on it. with SQLITE3 backup_server.db
And then I type .tables , I get an error that the file is encrypted or not a database file.
I tried the same on the older 1.4.9 Server there it works.
Is this normal ?
I did not change anything on this front with 1.4.10.
Thank you, I disabled backups for a complete day on the Server. It took it 10 hours to finish the cleanup . I guess the Core 2 Duo is not fast enough for a 4.5GB SQLite database. I have cpu usage 1.2 1.3 sometimes…
See here for tuning: http://blog.urbackup.org/177/performance-considerations-for-larger-urbackup-server-instances
Performance should be improved with the next major version.
I have put in a SSD disk , moved the Contents of /var/urbackup to it … databases , it is a lot faster now
Thank you.
