Is it possible to upgrade existing backup storage to the new 1.4 way? (Improved symlinking scheme)
I have a large number of backups with lots of files which don’t change often.
This is on windows.
Regards,
Matthijs ter Woord
This is on windows.
Regards,
Matthijs ter Woord
Yes it works seamlessly. You can also disable/enable it afterwards (don’t downgrade to 1.3, though!).
So when upgrading, I can have the storage be optimized, so that it starts using the new symlinking scheme?
Yes. Does it per default.
