I run an Urbackup Server on a Windows 10 PC. It ist working very well with some Windows Clients.
Now I try to use the client on an raspberry pi 3.
The Installation as described here (the TF= … command) seemed to work.
The client is discovered by the server and the service is running.
Now, when I try to add a backup directory, the following message is displayed:
urbackupclientctl add-backupdir Assertion failed: Unsupported .eh_frame_hdr version (…/…/src/c++/libunwind/src/EHHeaderParser.hpp: decodeEHHdr: 62)
The raspbian is up to date. I even reinstalled raspbian completely new
The Urbackup Client Versions that I tested are 2.1.15 and 2.1.16.
I also installed the linux client on a Windows 10 WSL Linux Shell. That works as expected.
Has this issue been resolved?
I just installed UrBackup on 2 of my pi’s and have this issue on both.
One is running raspbian and the other is retropi.
I cant seem to add any location no matter what i try, sudo or not.
Also, tried to do a urbackupclientctl set-settings and received the following error:
“urbackupclientctl: Permission denied
Cannot read backend password from /usr/local/var/urbackup/pw_change.txt”
This is only an issue with the error reporting. Call the command line interface correctly, or don’t use it and set up everything on the server web interface.
