Hello, I would like to know how to uninstall the urbackup-client-2.3.4 client in linux.
I think that uninstall_urbackupclient exists but I can not find it.
Thanks for the help.
Hi Aaroncastro,
This shoould do the trick (under Ubuntu):
sudo /usr/local/sbin/uninstall_urbackupclient
If it’s not there there try to find it with sudo locate (or do first sudo updatdb)
Hope that helps!
Hello, I use linux mint 18.3. I tried to find the file with find and locate and can not find it. Urbakup is working correctly.
