I am trying to make backup from a Windows 2012 Server. I want only backup files/folders but UrBackup client automatically selects all the SQL Server Databases that are running in this server. I unchecked all SQL databases from the “Configure components to backup” menú and save. But if I enter again, all SQL components are checked again automatically.
I don´t want to make SQL backup, maybe this is a bug?
Client version is: 2.3.6 CBT x64
Server version is: 2.3.8 in Debian Linux with BTRFS storage.
That was the problem!
I don´t know why but this occurs only when I put the server into a group, after change the “defautl=1” to “default=0” for the group, the problem has dissapear.
When I change the server config to default=0, all components are unchecked in the client, but the client does not save the new setting when I check some components.
The “Configure components to backup” option seems to be broken, and everything follows the server config.
