Gentlemen
As per subject. Somehow, I got it to work with 2.2.4 and everything was working fine and backing up as expected. Client 2.2.5 arrived and the existing 2.2.4 was updated. No errors whatsoever. Since then, I just can’t get it to work. No urbackup on the processes list when checked with TOP. Installation process went well. I also tried to remove it and install 2.2.6. Same thing. No luck. Can anyone please guide me where to look for problems? Thank you.
AAK
