Hi all
I have installed a urbackup instance via Docker on a Ubuntu 22.04 server but cannot get a set of firewall rules to work. If I disable ufw then my windows clients will see the server and start backing up, but if I enable the firewall with what I believe to be a correct set of rules configured, the clients never see the server.
My configuration is as follows:
Docker set-up:
sudo docker run -d \
--name urbackup \
--restart unless-stopped \
-e TZ="Europe/London" \
-v /mnt/disk0/urbackup/backups:/backups \
-v /mnt/disk0/urbackup/database:/var/urbackup \
--network=host \
--device /dev/zfs \
uroni/urbackup-server:latest
UFW rules:
sudo ufw allow 55413/tcp
sudo ufw allow 55414/tcp
sudo ufw allow 55415/tcp
sudo ufw allow out 35623/udp
Does anyone know what I might be missing here?
Thanks in advance,
Nick
