opened 10:33AM - 13 Jul 22 UTC
closed 07:11PM - 20 Jul 22 UTC
integration: shelly
### The problem
Hi there
This morning i had to reboot my PC for updated whic…h is running hypervisor and HA on a VM, once restarted i noticed all of my Generation 1 shelly devices unavailable (i have about 30 of them), all Generation 2 devices were still online, after rebooting a number of times, i then rebooted all shelly devices with no luck, then rebooted everything from Switches, Wifi, Gateway, VM Host, and still no luck
i first verified all of my gen 1 devices are running the current firmware of 20220209-094317/v1.11.8-g8c7bb8d and all also have the Colo it enabled pointing back to my HA server which is 192.168.X.X:5683
i then deleted onc shelly device and tried to re-add and got the following message
<img width="320" alt="2" src="https://user-images.githubusercontent.com/24925789/178708478-e4cc0f83-b347-40f0-a6f7-0da8ae7e2b5a.png">
note that if i delete a shelly device and then reboot, HA does auto discover it
i then factory reset the shelly unit, and still did the same issue as above . i then tried adding to configration.yaml a line to change the ColoIT port and then set it to the new port on a shelly, and no luck there either
i then decided to install a new install of HA on my VM (using the same hyper-v instance but with a new virtual disk,) meaning it kept the same IP, and then restored from a backup which was done two days ago when these were working with no luck, i then done another fresh install and starting a new HA system, which also done the same, and then reverted back to a older HA image i had with 8.1 and this also failed. i also tried changing IP addresses of the HA but keeping the same MAC of the VM and also no help there
after the tests above i believe i have ruled out the shellys and HA but the issue is still there, i can log into the units via web and control them with no issues and also i can confirm there is no firewall or blocking on the network as all these devices are on the same subnet
any help here would be greatly appreciated
### What version of Home Assistant Core has the issue?
core-2022.7.3
### What was the last working version of Home Assistant Core?
core-2022.7.3
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
Shelly
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/shelly
### Diagnostics information
logs turned off
### Example YAML snippet
```yaml
N/A as its an integrated setup
### Anything in the logs that might be useful for us?
```txt
2022-07-13 20:26:40 WARNING (MainThread) [homeassistant.config] Key whitelist_external_dirs has been replaced with allowlist_external_dirs. Please update your config
2022-07-13 20:26:41 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=630 from 2022-07-13 10:23:05)
2022-07-13 20:26:49 ERROR (MainThread) [snitun.client.client_peer] Challenge/Response error with SniTun server (0 bytes read on a total of 32 expected bytes)
2022-07-13 20:26:49 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-07-13 20:26:52 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-PL1PM-DISHWASHER' for shelly integration not ready yet: Cannot connect to host 192.168.199.174:80 ssl:default [Connect call failed ('192.168.199.174', 80)]; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-EM' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-UNI-SOLAR2' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-UNI-SOLAR1' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-2.5-KITCHEN' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-DIM2-LOUNGE' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-2.5-LAUNDRY' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-2.5-MASTER' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-1PM-BEDSIDE' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-1PM-HALLWAY' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-1PM-BEDROOM2' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-1PM-SPRINT' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-1PM-BEDROOM1' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-1PM-ROBE' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-2.5-FRONTDOOR' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-1PM-BATHROOM' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-2.5-BATHROOM' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-2.5-ENSUITE2' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-2.5-ENSUITE1' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-1PM-WASHING' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-UNI-ROLLER TRIGGER' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-1PM-BATHROOM-ALEXA' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-1PM-GARAGE-ALEXA' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-2.5-TOILET' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-2.5-GARAGE-TV' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-UNI-AUTOMATION-4' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-UNI-AUTOMATION-3' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-UNI-AUTOMATION-2' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-UNI-AUTOMATION-1' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-UNI-COMMS FAN' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:26:58 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SHELLY-UNI-LIZARD' for shelly integration not ready yet: Timeout during device setup; Retrying in background
2022-07-13 20:27:04 ERROR (MainThread) [snitun.client.client_peer] Challenge/Response error with SniTun server (0 bytes read on a total of 32 expected bytes)
2022-07-13 20:27:04 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-07-13 20:27:06 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.210 initialize error - TimeoutError()
2022-07-13 20:27:20 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.157 initialize error - TimeoutError()
2022-07-13 20:27:20 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.167 initialize error - TimeoutError()
2022-07-13 20:27:20 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.231 initialize error - TimeoutError()
2022-07-13 20:27:21 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.164 initialize error - TimeoutError()
2022-07-13 20:27:21 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.210 initialize error - TimeoutError()
2022-07-13 20:27:21 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.170 initialize error - TimeoutError()
2022-07-13 20:27:21 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.175 initialize error - TimeoutError()
2022-07-13 20:27:22 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.234 initialize error - TimeoutError()
2022-07-13 20:27:23 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.203 initialize error - TimeoutError()
2022-07-13 20:27:25 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.204 initialize error - TimeoutError()
2022-07-13 20:27:25 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.160 initialize error - TimeoutError()
2022-07-13 20:27:25 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.171 initialize error - TimeoutError()
2022-07-13 20:27:25 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.233 initialize error - TimeoutError()
2022-07-13 20:27:25 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.172 initialize error - TimeoutError()
2022-07-13 20:27:26 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.165 initialize error - TimeoutError()
2022-07-13 20:27:27 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.228 initialize error - TimeoutError()
2022-07-13 20:27:28 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.226 initialize error - TimeoutError()
2022-07-13 20:27:28 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.168 initialize error - TimeoutError()
2022-07-13 20:27:36 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.210 initialize error - TimeoutError()
2022-07-13 20:27:39 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.226 initialize error - TimeoutError()
2022-07-13 20:27:39 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.217 initialize error - TimeoutError()
2022-07-13 20:27:39 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.234 initialize error - TimeoutError()
2022-07-13 20:27:39 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.233 initialize error - TimeoutError()
2022-07-13 20:27:39 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.232 initialize error - TimeoutError()
2022-07-13 20:27:39 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.207 initialize error - TimeoutError()
2022-07-13 20:27:40 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.204 initialize error - TimeoutError()
2022-07-13 20:27:40 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.160 initialize error - TimeoutError()
2022-07-13 20:27:40 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.171 initialize error - TimeoutError()
2022-07-13 20:27:40 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.172 initialize error - TimeoutError()
2022-07-13 20:27:41 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.165 initialize error - TimeoutError()
2022-07-13 20:27:42 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.228 initialize error - TimeoutError()
2022-07-13 20:27:43 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.168 initialize error - TimeoutError()
2022-07-13 20:27:44 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.203 initialize error - TimeoutError()
2022-07-13 20:27:44 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.173 initialize error - TimeoutError()
2022-07-13 20:27:44 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.211 initialize error - TimeoutError()
2022-07-13 20:27:44 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.197 initialize error - TimeoutError()
2022-07-13 20:27:46 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.206 initialize error - TimeoutError()
2022-07-13 20:27:46 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.166 initialize error - TimeoutError()
2022-07-13 20:27:47 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.159 initialize error - TimeoutError()
2022-07-13 20:27:47 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.213 initialize error - TimeoutError()
2022-07-13 20:27:47 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.169 initialize error - TimeoutError()
2022-07-13 20:27:48 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.161 initialize error - TimeoutError()
2022-07-13 20:27:48 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.231 initialize error - TimeoutError()
2022-07-13 20:27:49 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.232 initialize error - TimeoutError()
2022-07-13 20:27:50 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.157 initialize error - TimeoutError()
2022-07-13 20:27:50 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.167 initialize error - TimeoutError()
2022-07-13 20:27:50 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.204 initialize error - TimeoutError()
2022-07-13 20:27:50 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.226 initialize error - TimeoutError()
2022-07-13 20:27:50 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.217 initialize error - TimeoutError()
2022-07-13 20:27:50 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.234 initialize error - TimeoutError()
2022-07-13 20:27:50 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.233 initialize error - TimeoutError()
2022-07-13 20:27:51 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.164 initialize error - TimeoutError()
2022-07-13 20:27:51 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.210 initialize error - TimeoutError()
2022-07-13 20:27:51 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.170 initialize error - TimeoutError()
2022-07-13 20:27:51 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.175 initialize error - TimeoutError()
2022-07-13 20:27:52 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.207 initialize error - TimeoutError()
2022-07-13 20:27:55 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.160 initialize error - TimeoutError()
2022-07-13 20:27:55 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.171 initialize error - TimeoutError()
2022-07-13 20:27:55 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.172 initialize error - TimeoutError()
2022-07-13 20:27:56 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.165 initialize error - TimeoutError()
2022-07-13 20:27:57 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.228 initialize error - TimeoutError()
2022-07-13 20:27:58 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.168 initialize error - TimeoutError()
2022-07-13 20:27:59 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.203 initialize error - TimeoutError()
2022-07-13 20:28:06 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.210 initialize error - TimeoutError()
2022-07-13 20:28:09 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.217 initialize error - TimeoutError()
2022-07-13 20:28:09 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.234 initialize error - TimeoutError()
2022-07-13 20:28:09 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.233 initialize error - TimeoutError()
2022-07-13 20:28:09 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.231 initialize error - TimeoutError()
2022-07-13 20:28:09 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.232 initialize error - TimeoutError()
2022-07-13 20:28:09 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.207 initialize error - TimeoutError()
2022-07-13 20:28:10 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.160 initialize error - TimeoutError()
2022-07-13 20:28:10 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.171 initialize error - TimeoutError()
2022-07-13 20:28:10 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.226 initialize error - TimeoutError()
2022-07-13 20:28:10 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.172 initialize error - TimeoutError()
2022-07-13 20:28:11 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.165 initialize error - TimeoutError()
2022-07-13 20:28:12 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.204 initialize error - TimeoutError()
2022-07-13 20:28:12 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.228 initialize error - TimeoutError()
2022-07-13 20:28:13 WARNING (MainThread) [aioshelly.block_device] device 192.168.199.168 initialize error - TimeoutError()
### Additional information
## System Health
version | core-2022.7.3
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.10.5
os_name | Linux
os_version | 5.15.45
arch | x86_64
timezone | Australia/Sydney
config_dir | /config
<details><summary>Home Assistant Cloud</summary>
logged_in | true
subscription_expiration | 15 July 2022 at 10:00
relayer_connected | true
remote_enabled | true
remote_connected | true
alexa_enabled | false
google_enabled | false
remote_server | ap-southeast-1-0.ui.nabu.casa
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 8.2
update_channel | stable
supervisor_version | supervisor-2022.07.0
agent_version | 1.2.1
docker_version | 20.10.14
disk_total | 30.8 GB
disk_used | 3.8 GB
healthy | true
supported | true
board | ova
supervisor_api | ok
version_api | ok
installed_addons | Samba share (10.0.0), File editor (5.3.3), MariaDB (2.4.0), Check Home Assistant configuration (3.11.0)
</details>
<details><summary>Dashboards</summary>
dashboards | 1
resources | 0
views | 5
mode | storage
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | 7 July 2022 at 09:10
current_recorder_run | 13 July 2022 at 20:26
estimated_db_size | 207.78 MiB
database_engine | mysql
database_version | 10.4.19
</details>
