Ubuntu 24.04 / kernel 6.8 — dm snapshot works but image capability bit (bit 2) not set in client binary
Environment:
  • UrBackup server: 2.5.31 (Infscape CE 1.14.0)
  • UrBackup client: 2.5.24
  • OS: Ubuntu 24.04.2 LTS, kernel 6.8.0
  • Snapshot method: Option 4 — device mapper snapshots
Issue:
After installing the Linux client and selecting option 4 (device mapper snapshots), the client reports capability_bits: 69632. Decoding this:
  • Bit 16 (dm snapshot support): :white_check_mark: set
  • Bit 2 (image backup capability): :cross_mark: not set
The server therefore never dispatches image backups to this client. File backups work correctly.
What we’ve confirmed:
  • dm_create_volume_snapshot succeeds — the snapshot device is created and mountable
  • The snapshot mechanism works; the client binary simply doesn’t advertise image capability to the server
  • dattobd is not available on kernel 6.8 (no Ubuntu 24.04 packages)
  • elastio-snap loads but has no UrBackup integration path
Secondary symptom: When snapshot attempts fail, the client leaves /.overlay_* files on the root filesystem. These are sparse files backed by the dm cow-storage device and can fill the root volume completely if left unchecked.
Question: Is there a known fix or workaround to force the image capability bit to be set for dm snapshots on kernel 6.8? Is this addressed in any client version after 2.5.24?
Does it set create_volume_snapshot in /usr/local/etc/urbackup/snapshot.cfg ?
Yes — create_volume_snapshot is set in snapshot.cfg:
create_volume_snapshot=/usr/local/share/urbackup/dm_create_snapshot
remove_volume_snapshot=/usr/local/share/urbackup/dm_remove_snapshot
The dm_create_snapshot script runs successfully and the snapshot device is created and mountable. The capability bit (bit 2) just isn’t being advertised to the server despite this.
Idk where you get this idea about this capability bit
Apologies — checking again now, capability_bits has changed from 69632 to 69644 since the server queued an image backup. Bit 2 is now set. We may have been looking at a stale value before the server had attempted to trigger an image backup. Is there a way to force an image backup now to test whether it proceeds?
