Greetings,
I am running urbackup server on a windows 2019 server. All my windows servers are backing up successfully, however I have a ubuntu 20.04 server that will not start a backup at all. I have enabled debug on the the management server and the client but don’t see anything useful.
here is the client log
2024-04-10 02:25:56: SQLite: recovered 39 frames from WAL file /usr/local/var/urbackup/backup_client.db-wal code: 283
2024-04-10 02:25:56: urbackupserver: Server started up successfully!
2024-04-10 02:25:56: Started UrBackupClient Backend…
2024-04-10 02:25:56: FileSrv: Binding UDP socket at port 35622…
2024-04-10 02:25:56: FileSrv: done.
2024-04-10 02:25:56: FileSrv: Binding ipv6 UDP socket at port 35622…
2024-04-10 02:25:56: FileSrv: Servername: -fcssql-
2024-04-10 02:25:56: FileSrv: Server started up successfully
2024-04-10 02:25:56: FileSrv: UDP Thread started
2024-04-10 02:25:57: urbackupserver: No available slots… starting new Worker
2024-04-10 02:25:57: Internet only mode not enabled. Waiting for local server for 3:00…
2024-04-10 02:25:57: Looking for old Sessions… 0 sessions
2024-04-10 02:25:57: Final path: /etc
2024-04-10 02:25:57: Final path: /home
2024-04-10 02:25:57: ClientService cmd: #Iov3igdJhLbp60UvZuOio#1CHANNEL capa=190731&token=QDxsboCwHpzPuWuNJ8Sn&restore_version=1&startup=1&virtual_client=
2024-04-10 02:25:57: New channel: Number of Channels: 1
2024-04-10 02:25:57: ClientService cmd: #Iov3igdJhLbp60UvZuOio#FILESRV
2024-04-10 02:25:57: Start FILESRV thread
2024-04-10 02:25:57: FileSrv: Received data…
2024-04-10 02:25:57: FileSrv: Received a Packet.
2024-04-10 02:25:57: FileSrv: Sending file (normal) urbackup/settings.cfg metadata_id=0
2024-04-10 02:25:57: FileSrv: Mapped name: /usr/local/var/urbackup/data/settings.cfg
2024-04-10 02:25:57: Received flush.
2024-04-10 02:25:57: FileSrv: Recv Error in RecvMessage
2024-04-10 02:25:57: ClientService cmd: #Iov3igdJhLbp60UvZuOio#SETTINGS update_freq_incr.group=18000
update_freq_incr=18000
update_freq_incr.use=1
update_freq_full.group=604800
update_freq_full=604800
update_freq_full.use=1
update_freq_image_full.group=-1296000
update_freq_image_full=-1296000
update_freq_image_full.use=1
update_freq_image_incr.group=-86400
update_freq_image_incr=-86400
update_freq_image_incr.use=1
max_file_incr.group=50
max_file_incr=50
max_file_incr.use=1
min_file_incr.group=10
min_file_incr=10
min_file_incr.use=1
max_file_full.group=4
max_file_full=4
max_file_full.use=1
min_file_full.group=2
min_file_full=2
min_file_full.use=1
min_image_incr.group=4
min_image_incr=4
min_image_incr.use=1
max_image_incr.group=15
max_image_incr=15
max_image_incr.use=1
min_image_full.group=1
min_image_full=1
min_image_full.use=1
max_image_full.group=2
max_image_full=2
max_image_full.use=1
startup_backup_delay.group=60
startup_backup_delay=60
startup_backup_delay.use=1
backup_window_incr_file.group=1-7/0-24
backup_window_incr_file=1-7/0-24
backup_window_incr_file.use=1
backup_window_full_file.group=1-7/0-24
backup_window_full_file=1-7/0-24
backup_window_full_file.use=1
backup_window_incr_image.group=1-7/0-24
backup_window_incr_image=1-7/0-24
backup_window_incr_image.use=1
backup_window_full_image.group=1-7/0-24
backup_window_full_image=1-7/0-24
backup_window_full_image.use=1
exclude_files.group=
exclude_files=
exclude_files.use=1
include_files.group=
include_files=
include_files.use=1
computername.group=
computername=
computername.use=1
virtual_clients.group=
virtual_clients=
virtual_clients.use=1
default_dirs.group=/etc/;/home/
default_dirs=/etc/;/home/
default_dirs.use=1
allow_overwrite.group=false
allow_overwrite=false
allow_overwrite.use=1
backup_dirs_optional.group=false
backup_dirs_optional=false
backup_dirs_optional.use=1
allow_config_paths.group=true
allow_config_paths=true
allow_config_paths.use=1
allow_starting_full_file_backups.group=true
allow_starting_full_file_backups=true
allow_starting_full_file_backups.use=1
allow_starting_incr_file_backups.group=true
allow_starting_incr_file_backups=true
allow_starting_incr_file_backups.use=1
allow_starting_full_image_backups.group=false
allow_starting_full_image_backups=false
allow_starting_full_image_backups.use=1
allow_starting_incr_image_backups.group=false
allow_starting_incr_image_backups=false
allow_starting_incr_image_backups.use=1
allow_pause.group=false
allow_pause=false
allow_pause.use=1
allow_log_view.group=true
allow_log_view=true
allow_log_view.use=1
allow_tray_exit.group=false
allow_tray_exit=false
allow_tray_exit.use=1
image_letters.group=ALL_NONUSB
image_letters=ALL_NONUSB
image_letters.use=1
internet_server=backups.mydomain.org
internet_server_def=backups.mydomain.org
internet_server_port=55415
internet_server_port_def=55415
internet_server_proxy=
internet_server_proxy_def=
internet_authkey.group=** redacted **
internet_authkey=** redacted **
internet_speed.group=-1
internet_speed=-1
internet_speed.use=1
local_speed.group=-1
local_speed=-1
local_speed.use=1
internet_image_backups.group=false
internet_image_backups=false
internet_image_backups.use=1
internet_full_file_backups.group=true
internet_full_file_backups=true
internet_full_file_backups.use=1
internet_encrypt.group=true
internet_encrypt=true
internet_encrypt.use=1
internet_compress.group=true
internet_compress=true
internet_compress.use=1
internet_mode_enabled.group=true
internet_mode_enabled=true
internet_mode_enabled.use=1
silent_update.group=true
silent_update=true
silent_update.use=1
client_quota.group=
client_quota=
client_quota.use=1
local_full_file_transfer_mode.group=hashed
local_full_file_transfer_mode=hashed
local_full_file_transfer_mode.use=1
internet_full_file_transfer_mode.group=raw
internet_full_file_transfer_mode=raw
internet_full_file_transfer_mode.use=1
local_incr_file_transfer_mode.group=hashed
local_incr_file_transfer_mode=hashed
local_incr_file_transfer_mode.use=1
internet_incr_file_transfer_mode.group=blockhash
internet_incr_file_transfer_mode=blockhash
internet_incr_file_transfer_mode.use=1
local_image_transfer_mode.group=hashed
local_image_transfer_mode=hashed
local_image_transfer_mode.use=1
internet_image_transfer_mode.group=raw
internet_image_transfer_mode=raw
internet_image_transfer_mode.use=1
end_to_end_file_backup_verification.group=false
end_to_end_file_backup_verification=false
end_to_end_file_backup_verification.use=1
internet_calculate_filehashes_on_client.group=true
internet_calculate_filehashes_on_client=true
internet_calculate_filehashes_on_client.use=1
internet_parallel_file_hashing.group=false
internet_parallel_file_hashing=false
internet_parallel_file_hashing.use=1
image_file_format.group=default
image_file_format=default
image_file_format.use=1
internet_connect_always.group=false
internet_connect_always=false
internet_connect_always.use=1
server_url=
server_url_def=
verify_using_client_hashes.group=false
verify_using_client_hashes=false
verify_using_client_hashes.use=1
internet_readd_file_entries.group=true
internet_readd_file_entries=true
internet_readd_file_entries.use=1
background_backups.group=true
background_backups=true
background_backups.use=1
local_incr_image_style.group=to-full
local_incr_image_style=to-full
local_incr_image_style.use=1
local_full_image_style.group=full
local_full_image_style=full
local_full_image_style.use=1
internet_incr_image_style.group=to-last
internet_incr_image_style=to-last
internet_incr_image_style.use=1
internet_full_image_style.group=synthetic
internet_full_image_style=synthetic
internet_full_image_style.use=1
create_linked_user_views.group=false
create_linked_user_views=false
create_linked_user_views.use=1
max_running_jobs_per_client.group=1
max_running_jobs_per_client=1
max_running_jobs_per_client.use=1
cbt_volumes.group=ALL
cbt_volumes=ALL
cbt_volumes.use=1
cbt_crash_persistent_volumes.group=-
cbt_crash_persistent_volumes=-
cbt_crash_persistent_volumes.use=1
ignore_disk_errors.group=false
ignore_disk_errors=false
ignore_disk_errors.use=1
vss_select_components.group=default=1
vss_select_components=default=1
vss_select_components.use=1
allow_file_restore.group=false
allow_file_restore=false
allow_file_restore.use=1
allow_component_restore.group=false
allow_component_restore=false
allow_component_restore.use=1
allow_component_config.group=false
allow_component_config=false
allow_component_config.use=1
file_snapshot_groups.group=
file_snapshot_groups=
file_snapshot_groups.use=1
image_snapshot_groups.group=
image_snapshot_groups=
image_snapshot_groups.use=1
internet_file_dataplan_limit.group=524288000000
internet_file_dataplan_limit=524288000000
internet_file_dataplan_limit.use=1
internet_image_dataplan_limit.group=2097152000000
internet_image_dataplan_limit=2097152000000
internet_image_dataplan_limit.use=1
alert_script.group=1
alert_script=1
alert_script.use=1
alert_params.group=
alert_params=
alert_params.use=1
archive.group=
archive=
archive.use=1
client_settings_tray_access_pw.group=
client_settings_tray_access_pw=
client_settings_tray_access_pw.use=1
local_encrypt.group=true
local_encrypt=true
local_encrypt.use=1
local_compress.group=true
local_compress=true
local_compress.use=1
download_threads.group=1
download_threads=1
download_threads.use=1
hash_threads.group=1
hash_threads=1
hash_threads.use=1
client_hash_threads.group=1
client_hash_threads=1
client_hash_threads.use=1
image_compress_threads.group=0
image_compress_threads=0
image_compress_threads.use=1
2024-04-10 02:25:57: rc=0 hasError=true state=0
2024-04-10 02:25:57: ClientService cmd: #Iov3igdJhLbp60UvZuOio#CAPA
2024-04-10 02:25:57: ClientService cmd: #IuTJAanwcwi2DbKTpeAmC#GET CHALLENGE with_enc=1
2024-04-10 02:25:57: ClientService cmd: ** redacted **
2024-04-10 02:26:27: ClientService cmd: GET BACKUP DIRS#pw=** redacted **
2024-04-10 02:26:27: rc=0 hasError=true state=0
2024-04-10 02:26:40: ClientService cmd: GET BACKUP DIRS#pw=** redacted **
2024-04-10 02:26:40: rc=0 hasError=true state=0
2024-04-10 02:26:57: ClientService cmd: PONG
2024-04-10 02:26:57: rc=0 hasError=true state=3
2024-04-10 02:26:57: ClientService cmd: #IXdn4szPOJA0Q5W2I8rKa#1CHANNEL capa=190731&token=QDxsboCwHpzPuWuNJ8Sn&restore_version=1&startup=1&virtual_client=
2024-04-10 02:26:57: New channel: Number of Channels: 1
2024-04-10 02:27:57: ClientService cmd: PONG
2024-04-10 02:28:57: ClientService cmd: PONG
here is the server side.
2024-04-09 22:30:05: Getting client settings…
2024-04-09 22:30:05: Flushing FileClient…
2024-04-09 22:34:53: msg=START BACKUP FULL
here is the status of the backend
● urbackupclientbackend.service - UrBackup Client backend
Loaded: loaded (/lib/systemd/system/urbackupclientbackend.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2024-04-10 02:25:56 UTC; 10min ago
Main PID: 24350 (urbackupclientb)
Tasks: 12 (limit: 19088)
Memory: 2.7M
CGroup: /system.slice/urbackupclientbackend.service
└─24350 /usr/local/sbin/urbackupclientbackend --config /etc/default/urbackupclient --no-consoletime
Apr 10 02:26:57 ** Redacted Hostname ** urbackupclientbackend[24350]: New channel: Number of Channels: 1
Apr 10 02:27:57 ** Redacted Hostname ** urbackupclientbackend[24350]: ClientService cmd: PONG
urbackupclientctl status
“capability_bits”: 256267,
“finished_processes”: ,
“internet_connected”: false,
“internet_status”: “connected_local”,
“last_backup_time”: 0,
“running_processes”: ,
“servers”: [{
“internet_connection”: false,
“name”: “192.168.1.4”
“time_since_last_lan_connection”: 16724
Where can i look for more information about what is happening here. I’ve wasted days on this and am about to throw in the towel. Windows firewall is disabled, UFW is disabled btw.
