The current debs won’t install on Ubuntu 10.04 LTD. The python libs are at 1.40, not 1.42.
- Will there be an issue if I compile?
- are there .debs for 10.04
Gerald
Gerald
Python is only used to display charts about storage usage. To decrease the dependencies the source archiv on the webpage uses google chart to do that. So there is no python depency at all .
So you should be able to compile it.
Regarding 2. I’ll try to add a decreased dependencies deb with the next version. Sadly I just added another dependency (libcurl for sending mails)
