I was wondering if there was a sure fire way to set the settings so that the incremental backup wouldn’t happen or if there is a way to turn it off.
Thanks in advance.
Thanks in advance.
You can enter a negative incremental backup interval. Then it won’t do incremental backups.
Sorry that’s so hidden.
Ahhh! Thank you very much! I had though to set it to zero, but not to a negative number.
Does this work for file and image incrementals?
Yes.
Hi forum,
that doesn’t work in my environment.
I configured “-1” for “Intervall für inkrementelle Image-Backups” and tried various settings for min and max. (0 0, 1 1, …)
The result is always the same: It creates incremental image backups every 10 minutes (approx.).
My environment:
Server:
Debian wheezy + urbackup-server 1.2.4-1_amd64
Clients:
Urbackup 1.2 on
1. Server 2003r2
2. Server 2008r2
Any help would be appreciated.
Can you try the newer version at http://sourceforge.net/projects/urbackup/files/WorkInProgress/ ?
