I have setup the urbackup client on Linux Mint as per the instructions from the link http://www.urbackup.org/ClientUbuntuOrDebianInstall.php?lang=en . The client is detected by server, but I am unable to start the urbackup client on the client PC and add backup paths,
Please help
Sorry. UrBackup uses wxWidgets to show the tray icon. So it is more a wxWidgets problem. If it does not work this is probably due to the tray icon API fragmentation. The tray icon is shown in a small window in Unity, and does not work either, for example.
If you do not need the info that a backup is taking place, you could setup everything on the server (via default paths to backup) and just use the background process.
