I have to move the backup location for urbackup files.
How to update the urbackup database in order to have the existing backup files in the db registered ?
Is there no way you can keep the old location?
It does move the image backups automatically, once it notices they do not exist anymore. It does not currently do that for file backups. It does however download the files from the client, if it realizes the old files are gone.
unfortunately I’ve have to use another Disk Letter (M: instead of N:) for the backup.
How does It move the image backups automatically, if they do not exist anymore ?
It doesn’t move the images. It searches for the images in the new location, if they are missing in the old location. So you can copy the images to the new location and they will be automatically picked up. The same does not work for files.
