I have in log many these errors:
ERROR: Error unserializing state data
ERROR: Error executing alert script id 1. Return value -1.
Any advice? Thank you very much!
Could you post the output of
echo "SELECT hex(alerts_state) FROM clients WHERE alerts_state IS NOT NULL AND length(alerts_state)>0;" | sqlite3 /var/urbackup/backup_server.db
? Thanks!
64
64
04166C6173745F696D6167655F6661696C5F6E6F7469667903
04156C6173745F66696C655F6661696C5F6E6F7469667903
64
64
64
64
64
64
64
Seems to be an issue with storing null bytes. I wonder why it works for me? Are you using a separate sqlite? Or are you not using Linux etc.?
I’m using Debian Stretch. Package sqlite3 is installed.
Just experienced the same issue.
urbackupsrv crashed due to it.
# cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.4 LTS"
# sqlite3 --version
3.22.0 2018-01-22 18:45:57 0c55d179733b46d8d0ba4d88e01a25e10677046ee3da1d5b1581e86726f2alt1
echo “SELECT hex(alerts_state) FROM clients WHERE alerts_state IS NOT NULL AND length(alerts_state)>0;” | sqlite3 /var/urbackup/backup_server.db
04156C6173745F66696C655F6661696C5F6E6F74696679030000004E2BF4D74164
04156C6173745F66696C655F6661696C5F6E6F7469667903000000C829F4D74164
04156C6173745F66696C655F6661696C5F6E6F7469667903000000E42BF4D74164
04156C6173745F66696C655F6661696C5F6E6F74696679030000004E2BF4D74104166C6173745F696D6167655F6661696C5F6E6F7469667903000000EAB3E1D74164
04156C6173745F66696C655F6661696C5F6E6F7469667903000000E629F4D74164
04156C6173745F66696C655F6661696C5F6E6F74696679030000005F29F4D74104166C6173745F696D6167655F6661696C5F6E6F74696679030000C09003E4D74164
04156C6173745F66696C655F6661696C5F6E6F74696679030000C0F627F4D74104166C6173745F696D6167655F6661696C5F6E6F74696679030000C0F627F4D74164
04156C6173745F66696C655F6661696C5F6E6F74696679030000C0F627F4D74164
04156C6173745F66696C655F6661696C5F6E6F74696679030000C0C828F4D74164
