Recently one of my machines didn’t start its backup. What I know:
Ports are open (verified with nmap)
both server and client see each other (pingable)
I can see client listed in webinterface
If I try to start backup from web interface, it states “queued backup” and does nothing.
If I try to start backup from client, I get “Timeout while waiting for server to start backup”.
Relevant live log on server:
09/06/16 02:02 INFO Starting incremental file backup...
09/06/16 02:02 DEBUG ns: Connecting for filelist...
09/06/16 02:02 DEBUG ns: Waiting for filelist
09/06/16 02:03 ERROR Constructing of filelist of "ns" failed - TIMEOUT(1)
09/06/16 02:03 ERROR Backup had an early error. Deleting partial backup.
09/06/16 02:08 INFO Starting incremental file backup...
09/06/16 02:08 DEBUG ns: Connecting for filelist...
09/06/16 02:08 ERROR Connecting to ClientService of "ns" failed - CONNECT error during filelist construction
09/06/16 02:08 ERROR Backup had an early error. Deleting partial backup.
09/06/16 02:08 WARNING Exponential backoff: Waiting at least 40m before next file backup
09/06/16 12:31 DEBUG Getting client settings...
09/06/16 12:31 DEBUG Sending backup incr interval...
09/06/16 12:32 DEBUG Cannot do image backup because can_backup_images=false
09/06/16 12:32 DEBUG Cannot do image backup because internet_no_images=true
Relevant log on server:
2016-09-06 02:04:15: Socket has error: 111
2016-09-06 02:04:25: Socket has error: 111
2016-09-06 02:04:35: Socket has error: 111
2016-09-06 02:04:45: Socket has error: 111
2016-09-06 02:04:55: Socket has error: 111
2016-09-06 02:05:05: Socket has error: 111
2016-09-06 02:05:15: Socket has error: 111
2016-09-06 02:05:25: Socket has error: 111
2016-09-06 02:05:35: Socket has error: 111
2016-09-06 02:05:45: Socket has error: 111
2016-09-06 02:05:55: Socket has error: 111
2016-09-06 02:06:05: Socket has error: 111
2016-09-06 02:06:15: Socket has error: 111
2016-09-06 02:06:25: Socket has error: 111
2016-09-06 02:06:35: Socket has error: 111
2016-09-06 02:06:45: Socket has error: 111
2016-09-06 02:06:55: Socket has error: 111
2016-09-06 02:07:05: Socket has error: 111
2016-09-06 02:07:15: Socket has error: 111
2016-09-06 02:07:25: Socket has error: 111
2016-09-06 02:07:35: Socket has error: 111
2016-09-06 02:07:45: Socket has error: 111
2016-09-06 02:07:55: Socket has error: 111
2016-09-06 02:08:05: Socket has error: 111
2016-09-06 02:08:15: Socket has error: 111
2016-09-06 02:08:21: Starting incremental file backup…
2016-09-06 02:08:21: Socket has error: 111
2016-09-06 02:08:21: ERROR: Connecting to ClientService of “ns” failed - CONNECT error during filelist construction
2016-09-06 02:08:25: Socket has error: 111
I keep getting “Getting client settings…” and “Cannot do <…>” lines every time I try to start backup.
I have the same problems as AckRite.
Can anyone help us? Log files are not helping to identify the cause.
Client log for file backup. It is a windows server 2012 R2 server
2019-10-21 00:03:04: WARNING: Info not found at ‘e:’ - reindexing 2019-10-21 10:22:48: Loaded -fileserv- plugin 2019-10-21 10:22:48: Loaded -fsimageplugin- plugin 2019-10-21 10:22:48: Loaded -cryptoplugin- plugin 2019-10-21 10:22:48: SQLite: recovered 148 frames from WAL file C:\Program Files\UrBackup\urbackup\backup_client.db-wal code: 283 2019-10-21 10:22:48: urbackupserver: Server started up successfully! 2019-10-21 10:22:48: FileSrv: Backup privileges set successfully 2019-10-21 10:22:48: FileSrv: Backup privileges set successfully (SE_SECURITY_NAME) 2019-10-21 10:22:48: FileSrv: Backup privileges set successfully (SE_RESTORE_NAME) 2019-10-21 10:22:48: Started UrBackupClient Backend… 2019-10-21 10:22:48: FileSrv: Binding UDP socket at port 35622… 2019-10-21 10:22:48: FileSrv: done. 2019-10-21 10:22:48: FileSrv: Disabling new behavior… 2019-10-21 10:22:48: FileSrv: Binding ipv6 UDP socket at port 35622… 2019-10-21 10:22:48: FileSrv: done. 2019-10-21 10:22:48: FileSrv: Disabling new behavior… 2019-10-21 10:22:48: Filesystem. Vol="\?\Volume{bcf267a6-6f7d-11e4-80b4-806e6f6e6963}" Name=“reservado pelo sistema” Type=“ntfs” VPaths=0 Size=366997504 2019-10-21 10:22:48: FileSrv: Servername: -ADVW12ACD01- 2019-10-21 10:22:48: FileSrv: Server started up successfully 2019-10-21 10:22:48: FileSrv: UDP Thread started 2019-10-21 10:22:48: Bootable flag set for volume 2019-10-21 10:22:48: Found potential candidate: \?\Volume{bcf267a6-6f7d-11e4-80b4-806e6f6e6963}\ Score: 3 2019-10-21 10:22:48: Filesystem. Vol="\?\Volume{dc3f6609-7068-11e4-80ba-00090ffe0001}" Name=“dados” Type=“ntfs” VPaths=1 Size=53683941376 2019-10-21 10:22:48: Bootable flag not set for volume 2019-10-21 10:22:48: Filesystem. Vol="\?\Volume{32630790-7115-11e4-80bb-00090ffe0001}" Name=“copia de sombra” Type=“ntfs” VPaths=1 Size=10734268416 2019-10-21 10:22:48: Bootable flag not set for volume 2019-10-21 10:22:48: Filesystem. Vol="\?\Volume{bcf267a7-6f7d-11e4-80b4-806e6f6e6963}" Name="" Type=“ntfs” VPaths=1 Size=42580570112 2019-10-21 10:22:48: Filesystem is System partition. Skipping… 2019-10-21 10:22:48: urbackupserver: No available slots… starting new Worker 2019-10-21 10:22:48: ClientService cmd: STATUS#pw=UYjSSGKJfje2USeLHYeGQtT3qQSnq5 2019-10-21 10:22:49: Internet mode not enabled 2019-10-21 10:22:49: Looking for old Sessions… 0 sessions 2019-10-21 10:22:49: Final path: E:\Arquivos 2019-10-21 10:22:49: Final path: E:\Backup_AD 2019-10-21 10:22:49: Filesystem. Vol="\?\Volume{bcf267ae-6f7d-11e4-80b4-806e6f6e6963}" Name="" Type="" VPaths=1 Size=-1 2019-10-21 10:22:49: GetVolumeInformation failed with error code 21. Skipping… 2019-10-21 10:22:49: Filesystem. Vol="\?\Volume{8c4dd971-dd60-11e9-8147-806e6f6e6963}" Name="" Type="" VPaths=1 Size=-1 2019-10-21 10:22:49: GetVolumeInformation failed with error code 21. Skipping… 2019-10-21 10:22:49: Selected volume \?\Volume{bcf267a6-6f7d-11e4-80b4-806e6f6e6963} 2019-10-21 10:22:49: System dir: C:\Windows 2019-10-21 10:22:49: Volpath: \.\C: 2019-10-21 10:22:49: Device is not GPT formatted (0) 2019-10-21 10:22:49: Found no EFI System Partition 2019-10-21 10:22:49: ClientService cmd: #ILTBzjuCKLUHV22DgLfFT#1CHANNEL capa=64&token=cA2XSY0u8YgxZbJAATsR&restore_version=1&virtual_client= 2019-10-21 10:22:49: New channel: Number of Channels: 1 2019-10-21 10:23:40: ClientService cmd: STATUS#pw=UYjSSGKJfje2USeLHYeGQtT3qQSnq5 2019-10-21 10:23:50: ClientService cmd: PONG 2019-10-21 10:24:31: ClientService cmd: STATUS#pw=UYjSSGKJfje2USeLHYeGQtT3qQSnq5 2019-10-21 10:24:49: ClientService cmd: PONG 2019-10-21 10:25:23: ClientService cmd: STATUS#pw=UYjSSGKJfje2USeLHYeGQtT3qQSnq5 2019-10-21 10:25:49: Internet mode not enabled 2019-10-21 10:25:49: ClientService cmd: PONG 2019-10-21 10:26:15: ClientService cmd: STATUS#pw=UYjSSGKJfje2USeLHYeGQtT3qQSnq5 2019-10-21 10:26:49: ClientService cmd: PONG 2019-10-21 10:27:07: ClientService cmd: STATUS#pw=UYjSSGKJfje2USeLHYeGQtT3qQSnq5 2019-10-21 10:27:50: ClientService cmd: PONG 2019-10-21 10:27:59: ClientService cmd: STATUS#pw=UYjSSGKJfje2USeLHYeGQtT3qQSnq5 2019-10-21 10:28:50: ClientService cmd: PONG 2019-10-21 10:28:51: ClientService cmd: STATUS#pw=UYjSSGKJfje2USeLHYeGQtT3qQSnq5 2019-10-21 10:29:43: ClientService cmd: STATUS#pw=UYjSSGKJfje2USeLHYeGQtT3qQSnq5 2019-10-21 10:29:50: ClientService cmd: PONG
Backup server log. It is a CentOS 7 server.
2019-10-21 10:25:01: Starting HTTP-Server on port 55414 2019-10-21 10:25:01: ERROR: HTTP: Failed binding socket to port 55414. Another instance of this application may already be active and bound to this port. 2019-10-21 10:25:01: Started UrBackup… 2019-10-21 10:25:01: Removing temporary files… 2019-10-21 10:25:01: Recreating temporary folder… Backupfolder not set 2019-10-21 10:25:01: Image mounting disabled: Backupfolder not set 2019-10-21 10:25:01: Testing if backup destination can handle subvolumes and snapshots… Backupfolder not set 2019-10-21 10:25:01: Backup destination cannot handle subvolumes and snapshots. Snapshots disabled. 2019-10-21 10:25:01: Testing if backup destination can handle filesystem transactions… 2019-10-21 10:25:01: Testing for hardlinks in backup destination… 2019-10-21 10:25:01: Could create hardlink at backup destination. Hardlinks enabled. 2019-10-21 10:25:01: Testing for reflinks in backup destination… 2019-10-21 10:25:01: Reflink ioctl failed. errno=95 2019-10-21 10:25:01: Could not create reflink at backup destination. Reflinks disabled. Operation not supported (code: 95) 2019-10-21 10:25:01: Binding to interface ens32 (ipv4) for broadcasting… 2019-10-21 10:25:01: Broadcasting on ipv4 interface ens32 addr 192.168.254.6 2019-10-21 10:25:01: Binding to interface ens32 (ipv6) for broadcasting… 2019-10-21 10:25:01: Broadcasting on ipv6 interface ens32 addr 2804:7f7:a5ad:125d:527f:83f2:7a0c:f4e2 2019-10-21 10:25:01: Binding to interface ens32 (ipv6) for broadcasting… 2019-10-21 10:25:01: Broadcasting on ipv6 interface ens32 addr fe80::7742:4a4a:ee89:5e14 2019-10-21 10:25:01: UrBackup Server start up complete. 2019-10-21 10:25:01: ERROR: Failed binding SOCKET to Port 55413 2019-10-21 10:25:01: ERROR: Error while starting listening to ports. Stopping server. 2019-10-21 10:25:01: Exited Loop 2019-10-21 10:25:01: Deleting at… 2019-10-21 10:25:01: Deleting SelectThreads… 2019-10-21 10:25:01: Deleting lbs… 2019-10-21 10:25:01: Shutting down plugins… 2019-10-21 10:25:01: Deleting server…
 Aprenda a pronunciar
The environment is all local, I don’t need external access. No firewall on the enabled server or client. Already checked the anti-virus and the service is released to any port. All in the same IP range.
