Hi, in windows 10 when a client add Documents folder in backup path, urbackup follow the symbolic link and backup also image downloads and music.
There is a way to disable the symlunk follow?
regards.
regards.
UrBackup is all about symbolic links; you can add in certain exclusion rules to prevent backing up certain files.
I believe the format you are looking for in exclusions is this:
*/Downloads/; */Music/
I believe that does what you are looking for; take a look at the manual for further assistance about how to set up exclusions and inclusions: https://www.urbackup.org/administration_manual.html#x1-630008.3.3
Thanks indeed should work
