The authorization header is malformed; the region 'us-east-1' is wrong; expecting 'fr-par'
I have been using URBACKUP for several months now and I am very satisfied with it. I decided to install Infscape to have the S3 option for storage. I have a problem with the S3 settings.
Here is the error:
Error verifying cloud storage settings:
2020-06-30 14:18:15: AES key length=32
2020-06-30 14:18:15: All depenencies available. Starting up…
2020-06-30 14:18:15: Total available RAM: 3.85219 GB
2020-06-30 14:18:15: Database with identifier “40” couldn’t be opened
2020-06-30 14:18:15: Retrieving object cd_magic_file
2020-06-30 14:18:16: WARNING: AWS-Client: Encountered Unknown AWSError ‘AuthorizationHeaderMalformed’: The authorization header is malformed; the region ‘us-east-1’ is wrong; expecting ‘fr-par’
2020-06-30 14:18:16: ERROR: AWS-Client: HTTP response code: 400
Exception name: AuthorizationHeaderMalformed
Error message: Unable to parse ExceptionName: AuthorizationHeaderMalformed Message: The authorization header is malformed; the region ‘us-east-1’ is wrong; expecting ‘fr-par’
I’m using S3 from scaleway hosted in France.
How can I fix my error?
Thank you in advance.
Seems Scaleway needs a work-around. This is implemented in the 9.12 appliance version. If you are starting out anyway, replace the appliance image by replacing the “11” in the download links at https://www.infscape.com/urbackup-appliance-download/ with 12. E.g.
https://infscape-appliance.s3.amazonaws.com/images/urbackup-app-9-12.vhd.zip
I couldn’t get the cloud image to work on Scaleway, so I’m assuming you don’t use it on one of their virtual machines? I couldn’t get their web console to work, so I couldn’t even debug the problem…
Thank you for your answer, I’ll try it today and I’ll come back for more news.
This version fixes the connection problem. the file system was correctly created on the S3. I test until the end of this week
It looks good.
Thank you very much.
little feedback, Infscape works very well with Scaleway S3 compatible.
Thanks for the fast response and resolution.
