I have noted that some files are left behind in the temp directory:
- After all backups are done - as in the web interface shows nothing active
- Failed restore
Surely there should be no more files left in the temp directory if the backup completed without issues ?
To avoid 100000’s in a single directory, can we not create a directory for each job, something like clientname_jobid ? This is also easy to clean up after the fact ?
