Both of our physical hardware based appliances failed the automatic upgrade to version 11.9 both with same errror message, I rebooted the appliances, but still the same issue
it looks like some type of mount issue
System update failed with following message:
+++ dirname /var/urbackup/firmware_update_10/apply.sh
++ cd /var/urbackup/firmware_update_10
++ pwd
- DIR=/var/urbackup/firmware_update_10
++ cat /var/urbackup/firmware_update_10/firmware_version - CURRENT_VERSION=11.9
++ cat /firmware_type - FIRMWARE_TYPE=amd64
- mkdir -p /media/fs
- test -e /media/fs/sys_root_current
- test -e /root_device
++ cat /root_device - ROOT_DEV=/dev/disk/by-uuid/e5c687e3-8188-426c-9f46-d4d1173ade34
- mount /dev/disk/by-uuid/e5c687e3-8188-426c-9f46-d4d1173ade34 /media/fs -o defaults,noatime,compress-force=lzo
- mount
- grep /media/fs
- grep zstd
- mount -o remount,compress-force=zstd /media/fs
- mount
- grep /media/fs
- grep zstd:15
- mount -o remount,compress-force=zstd:15 /media/fs
- exists ‘/boot/*.new’
- [[ -e /boot/*.new ]]
- [[ amd64 != \r\p\i\4 ]]
++ wc -l
++ ls /boot/vmlinuz-5.10.103 /boot/vmlinuz-5.10.128 - NUM_OLD_KE RNELS=2
- KERNEL_NUM=0
++ sort --version-sort
++ ls /boot/vmlinuz-5.10.103 /boot/vmlinuz-5.10.128 - for i in
ls /boot/vmlinuz-* | sort --version-sort - KERNEL_NUM=1
- ‘[’ 1 -ge 2 ‘]’
- VER=5.10.103
- rm /boot/System.map-5.10.103
- true
- rm /boot/System.map-5.10.103.xz
- true
- rm /boot/config-5.10.103
- true
- rm /boot/config-5.10.103.xz
- rm /boot/initrd.img-5.10.103
- rm /boot/vmlinuz-5.10.103
- for i in
ls /boot/vmlinuz-* | sort --version-sort - KERNEL_NUM=2
- ‘[’ 2 -ge 2 ‘]’
- break
- BOOT_FILES=‘zImage zImageXU4 kernel8.img cmdline.txt vmlinuz-5.10.172 config-5.10.172.xz initrd.img-5.10.172 grublegacy.cfg grub/grub.cfg fixup.dat fixup_cd.dat fixup_db.dat fixup_x.dat fixup4.dat fixup4cd.dat fixup4db.dat fixup4x.dat start.elf start_cd.elf start_db.elf start_x.elf start4.elf start4cd.elf start4db.elf start4x.elf’
- HAS_BOOT_FILE=no
- for fn in $BOOT_FILES
- test -e /var/urbackup/firmware_update_10/zImage< br>+ for fn in $BOOT_FILES
- test -e /var/urbackup/firmware_update_10/zImageXU4
- test -e /var/urbackup/firmware_update_10/kernel8.img
- test -e /var/urbackup/firmware_update_10/cmdline.txt
- test -e /var/urbackup/firmware_update_10/vmlinuz-5.10.172
- HAS_BOOT_FILE=yes
- cp /var/urbackup/firmware_update_10/vmlinuz-5.10.172 /boot/vmlinuz-5.10.172.new
- test -e /var/urbackup/firmware_update_10/config-5.10.172.xz
- HAS_BOOT_FILE=yes
- cp /var/urbackup/firmware_update_10/config-5.10.172.xz /boot/config-5.10.172.xz.new
- test -e /var/urbackup/firmware_update_10/initrd.img-5.10.172
- HAS_BOOT_FILE=yes
- cp /var/urbackup/firmware_update_10/initrd.img-5.10.172 /boot/initrd.img-5.10.172.new
- test -e /var/urbackup/firmware_update_10/grublegacy.cfg
- HAS_BOOT_FILE=yes
- cp /var/urbackup/fi rmware_update_10/grublegacy.cfg /boot/grublegacy.cfg.new
- test -e /var/urbackup/firmware_update_10/grub/grub.cfg
- HAS_BOOT_FILE=yes
- cp /var/urbackup/firmware_update_10/grub/grub.cfg /boot/grub/grub.cfg.new
- test -e /var/urbackup/firmware_update_10/fixup.dat
- test -e /var/urbackup/firmware_update_10/fixup_cd.dat
- test -e /var/urbackup/firmware_update_10/fixup_db.dat
- test -e /var/urbackup/firmware_update_10/fixup_x.dat
- test -e /var/urbackup/firmware_update_10/fixup4.dat
- test -e /var/urbackup/firmware_update_10/fixup4cd.dat
- test -e /var/urbackup/firmware_update_10/fixup4db.dat
- test -e /var/urbackup/firmware_update_10/fixup4x.dat
- test -e /var/urbackup/firmware_update_ 10/start.elf
- test -e /var/urbackup/firmware_update_10/start_cd.elf
- test -e /var/urbackup/firmware_update_10/start_db.elf
- test -e /var/urbackup/firmware_update_10/start_x.elf
- test -e /var/urbackup/firmware_update_10/start4.elf
- test -e /var/urbackup/firmware_update_10/start4cd.elf
- test -e /var/urbackup/firmware_update_10/start4db.elf
- test -e /var/urbackup/firmware_update_10/start4x.elf
++ shopt -s nullglob
++ echo - test -n ‘’
- test -e /var/urbackup/firmware_update_10/overlays
- ‘[’ -e /cloud-mode ‘]’
- ‘[’ -e /boot/grub/grub.cfg.new ‘]’
- ‘[’ -e /var/urbackup/mitigations_off ‘]’
- ‘[’ -e /boot/grublegacy.cfg.new ‘]’
- ‘[’ yes = yes ‘]’
- syncfs /boot
- sync -f /boot
- for fn in $BOO T_FILES
- mv -f /boot/vmlinuz-5.10.172.new /boot/vmlinuz-5.10.172
- mv -f /boot/config-5.10.172.xz.new /boot/config-5.10.172.xz
- mv -f /boot/initrd.img-5.10.172.new /boot/initrd.img-5.10.172
- mv -f /boot/grublegacy.cfg.new /boot/grublegacy.cfg
- test -e /var/urbackup/firmware_update_ 10/grub/grub.cfg
- mv -f /boot/grub/grub.cfg.new /boot/grub/grub.cfg
- test -e /var/urbackup/firmware_update_10/start.elf
- test -e /var/urbackup/firmware_update_10/st art_db.elf
- ‘[’ yes = yes ‘]’
- syncfs /boot
- sync -f /boot
- ‘[’ yes = yes ‘]’
- exists /boot/vmlinuz-5.10.128 /boot/vmlinuz-5.10.172
- [[ -e /boot/vmlinuz-5.10.128 ]]
- chmod +r /boot/vmlinuz-5.10.128 /boot/vmlinuz-5.10.172
- test -e /media/fs/sys_root_v11.9
- test -e /media/fs/sys_etc_v11.9
- cat /var/urbackup/firmware_update_10/root_update.btrfs.xz
- xz -d
- btrfs receive /media/fs
ERROR: cannot find parent subvolume - test -e /media/fs/sys_root_v11.9
- exit 1
