Ubuntu 18.04 guest on VMWare host, backing up Windows 2008R2 and 2012 servers. Backups are to removable drive, formatted NTFS. Everything updated to 2.4.8 over the weekend, and now I get (after an apparently otherwise successful backup) the error above Syncing file system failed. Backup is not completely on disk. Invalid argument (code: 22)
2.3.8 version works fine, but yesterday i was update container to image with version 2.4.9, my commands:
docker rm -f urbackup-server
docker pull uroni/urbackup-server
… and same command as above
Two Windows 7 64bit machines with clients installed provide backups to server 2.3.8, but cannot work with 2.4.9. It log the same error as thread header.
Docker container starting in CentOS 7, volume ‘/mnt/toshiba2tb’ is linked to HDD 2Tb with one NTFS-partition.
I have this exact same issue. Started Monday after an upgrade of a linux box and upgrade of UR product (client and server). Also using ntfs-3g version 2017.3.23.11.el7 (upgraded from 2017.3.23-6.el7).
Same error: 2019.10.22 23:26:59(error): Syncing file system failed. Backup is not completely on disk. Invalid argument (code: 22)
My environment consists of thus:
- Server: CentOS 7.7.1908 (just upgraded from 7.6) running URBackup 2.4.9 (just upgraded from 2.3.8).
- Clients:
CentOS 7.7.1908 (just upgraded from 7.6) running URBackup client 2.4.8 (just upgraded from 2.3.4)
Server 2012R2 running URClient 2.4.8 (also just upgraded from 2.3.4)
Server 2019 running URClient 2.4.8 (also just upgraded for 2.3.4)
A lot of moving parts for troubleshooting, but I figure the more information the better.
Thank you for any and all assistance… and being new to the forum, thank you for the fantastic product and it’s availability. It has saved me some hard $$$ and some even harder conversations with my administration and advisory committee.
I have the same problem with the new versions - 2.4.9 on server and 2.4.8 on client.
OS on server and client:
Raspbian GNU/Linux 9.11 (stretch)
Linux version 4.19.66-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1253 SMP Thu Aug 15 11:49:46 BST 2019
Backup storage:
HDD 5TB with one NTFS-Partition
Log:
Info
25.10.19 20:50
Starting unscheduled full file backup…
Info
25.10.19 20:50
Backing up “sys_home” without snapshot.
Info
25.10.19 20:50
Indexing of “sys_home” done. 13 filesystem lookups 0 db lookups and 0 db updates
Info
25.10.19 20:50
RASPBERRYFIX: Loading file list…
Info
25.10.19 20:50
RASPBERRYFIX: Started loading files…
Info
25.10.19 20:50
Referencing snapshot on “RASPBERRYFIX” for path “sys_home” failed: FAILED
Info
25.10.19 20:50
Waiting for file transfers…
Info
25.10.19 20:51
mariadbdump.sql: Starting backup of MariaDB at Fri Oct 25 20:51:09 CEST 2019…
Info
25.10.19 20:51
mariadbdump.sql: Backup of MariaDB finished at Fri Oct 25 20:51:20 CEST 2019.
Info
25.10.19 20:51
Waiting for file hashing and copying threads…
Info
25.10.19 20:52
Writing new file list…
Info
25.10.19 20:52
All metadata was present
Errors
25.10.19 20:52
Info
25.10.19 20:52
Transferred 379.108 MB - Average speed: 76.388 MBit/s
Info
25.10.19 20:52
Time taken for backing up client RASPBERRYFIX: 1m 50s
