Hi guys,
i did a remove-unknown to make sure DB and files are in sync. I have 2 server running and i check the time and consumption of both backups.
|Computername|Abbilder|Dateien|Alle|
|SERVER230|14.28 GB|10.11 TB|10.12 TB|
|SERVER231|29.49 GB|2.63 TB|2.66 TB|
Server230 has 4 times more than server231 on files in the backup space. But remove-unknown behaves the other way.
2022-06-26 13:34:43: Removing unknown for client “SERVER230”
2022-06-26 13:41:32: Removing unknown for client “SERVER231”
2022-06-26 14:34:26: Removing unknown for client “XXXX”
Server230 updates takes ~7 minutes to run through while server231 takes 53 minutes!?
Last backup run on Server230: Indexing of “F” done. 253 filesystem lookups 1845036 db lookups and 39 db updates
Last backup run on Server231: Indexing of “F” done. 288 filesystem lookups 716076 db lookups and 205 db updates
So how is it possible that remove-unknown runs must faster on server230 data entrys? Even Server230 has 4 times the backup size and 2,5 times on files as server231?
Any hints?
