Buzzz
July 16, 2021, 1:48pm
1
My urbackup is stuck in this state:
how can I get some info? State of my S3 storage is good.
Mount operation in progress. Backup storage will become available shortly. (________)
Current action:
Mounting file system…
And I can’t send report problem, error ‘Error reporting problem: Internal problem report issue’
uroni
July 16, 2021, 2:00pm
2
Sorry for the problems…
If possible could you have a look at the log file /var/log/app.log to see if this gives any hints w.r.t. the issue? Possibly via web console (Settings → System → Access server web shell) or ssh (if enabled in Settings → System) (become root via sudo -i, login as admin).
Buzzz
July 16, 2021, 2:16pm
3
021-07-16 16:15:17,030 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:17,306 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:17,577 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:17,850 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:18,124 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:18,397 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:18,673 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:18,950 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:19,220 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:19,493 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:19,767 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:20,042 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:20,315 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:20,587 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:20,857 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:21,130 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:21,402 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:21,673 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:15:21,945 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
Buzzz
July 16, 2021, 3:24pm
4
others:
2021-07-16 15:43:33,636 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 15:43:33,908 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 15:43:34,183 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 15:44:13,669 ERROR: No id in report problem result: {‘err’: ‘Device not found’} [in /root/urbackup-app-server/urbackup_app_server/report_problem.py:105]
2021-07-16 15:44:34,518 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 15:44:34,793 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
Buzzz
5
2021-07-16 16:18:41,043 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:18:41,317 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:18:41,589 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:18:41,860 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:19:16,493 ERROR: _get_response exception: (<class ‘OSError’>, OSError(101, ‘Network is unreachable’), <traceback object at 0x7fdc6ec8f348>) [in /root/urbackup-app-server/urbac$
2021-07-16 16:19:42,154 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:19:42,426 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
2021-07-16 16:19:42,694 ERROR: Handling event id s3_backend failed [in /root/urbackup-app-server/events.py:857]
Buzzz
July 16, 2021, 3:26pm
6
2021-07-16 17:19:16,390 ERROR: _get_response exception: (<class ‘OSError’>, OSError(101, ‘Network is unreachable’), <traceback object at 0x7f66f7470548>) [in /root/urbackup-app-server/urbac$
uroni
July 16, 2021, 3:50pm
7
There wasn’t an appliance with your name registered to your account. I’ve added it manually. It should send you the S3 error now and reporting problems should also work now.
Buzzz
July 16, 2021, 3:52pm
8
I searched the logs and found the S3 errors.
Thanks you
