Version 2.3.7 running on Windows Server 2019 Standard. After a storage migration using the procedures defined in the manual I have a wildly fluctuating inode_db folder. I found in other posts that it can be deleted after migration is completed. Even though I was successfully able to delete it, it comes back and its size toggles between 1TB and 68GB within a few minutes. There’s nothing in the logs that I can find and backups are working normally. I have two clients…one is the server’s system disk and the other is a windows 7 desktop system disk.
Why does it keep coming back after deletion and why does it toggle its size so drastically in so little time?
Thank you,
