Stuipd question, when 5 client has the same name and all should backup over Internet.
How can this solved? Is there a way to make groups? Or can i give every client a special note so i know which client is on which side?
Greetings Mario
Greetings Mario
Can’t you give them different names? It should work that you create different internet clients and then download the preconfigured client from the server or set the computername accordingly.
totally agree if you manually create a INTERNET CLIENT and give it a different name
Then on the client side settings enter that SAME Client Name you gave it
Wa La you have asigned different names without changeing the NETBIOS HOST name
