I’m running with debug logs enable on both the server and the client. The server doesn’t say anything. The client only gives the following output:
2016-09-26 08:40:19: urbackupserver: Server started up successfully!
2016-09-26 08:40:19: FileSrv: Server started up successfully
2016-09-26 08:40:19: Started UrBackupClient Backend…
2016-09-26 08:40:20: Looking for old Sessions… 0 sessions
2016-09-26 08:40:21: Trying to connect to internet server “http://backups.example.com/” at port 55415
2016-09-26 08:40:21: Socket has error: 111
2016-09-26 08:40:21: Connecting failed.
The server in question where I am running the client worked before. But because of some bugs in urbackup I decided to remove the client and reinstall. Since then I can’t connect on any server where I removed the client from the webui and reinstalled the client on the server.
What could be causing this? Is there any way to really properly completely wipe urbackup off of a system?
I tried using find to search for any reference to files and directories containing the string “urbackup” and delete those from my clients.
For some reason, I have one client which works. That one is so far the only that works.
How can I debug this further, or are there any files where urbackup stores information on clients that I could edit or delete?
