DDD
February 12, 2020, 10:42am
#1
Hi.
Does urbackup client 2.4.10 work on SUSE Linux Enterprise Server 11 kernel 2.6.27 ?
Returns an error in the logs:
SQLite: recovered 24 frames from WAL file /usr/local/var/urbackup/backup_client.db-wal code: 283
ERROR: urbackupserver: Creating v6 SOCKET failed
urbackupserver: Server started up successfully!
Started UrBackupClient Backend…
ERROR: FileSrv: Failed setting SO_REUSEADDR in CUDPThread::CUDPThread
ERROR: Binding ipv6 UDP socket to port 35622 failed
FileSrv: Servername: ********
Looking for old Sessions… 0 sessions
WARNING: Shutting down (Signal 2)
Deleting lbs…
Shutting down plugins…
Deleting server…
uroni
February 12, 2020, 10:53am
#2
Is that the binary client or self-compiled? It seems to work? Is it not connecting?
Can you run strace on it? You could also try the one posted here, though SO_CLOEXEC seems to be added to Linux with exactly 2.6.27. CentOS 5 client compatibility
DDD
February 12, 2020, 12:07pm
#3
This is a binary client. Does not work.
~ urbackupclientctl status
Error getting status
Please tell me how to run strace? And I didn’t quite understand what you can try from the post:
DDD
February 27, 2020, 7:46am
#4
urbackupclient.log (1.1 KB)
urbackupclient_strace.log (9.4 KB)
set
https://beta.urbackup.org/tmp/UrBackupUpdateLinux-dbg.sh
it still doesn’t work, the errors are the same.
This client appeared in the web interface of the server, but backup fails to start (and configure folders for backup too)
DDD
February 28, 2020, 6:46am
#5
Hi.
As I understand it, the client 1.4.11 works on older versions of Linux?
Tell me, please, where can I download it from?
DDD
March 13, 2020, 5:30am
#6
Hi, uroni.
Could you lay out the binary package of the client 1.4.11? (Not compiled from source code)
Thank you very much!
