Hi
We regularly have sigterms with backups and we do not understand why.
The client is version 2.1.16 on a debian 8.9 and a kernel 3.16.0-4-amd64 # 1 SMP Debian 3.16.43-2 + deb8u3
root @ sd-89425: ~ # service urbackupclientbackend status
● urbackupclientbackend.service - UrBackup Client backend
Loaded: loaded (/lib/systemd/system/urbackupclientbackend.service; enabled; vendor preset: enabled)
Active: failed (Result: signal) since Mon. 2017-09-04 21:57:15 CEST; 581ms ago
Process: 2489 ExecStart = / usr / local / sbin / urbackupclientbackend --config/etc/default/ urbackupclient --no-consoletime (code = killed, signal = SEGV)
Main PID: 2489 (code = killed, signal = SEGV)
Sep 04 21:54:15 sd-89425 systemd [1]: Started UrBackup Client backend.
Sep-04 21:57:15 sd-89425 systemd [1]: urbackupclientbackend.service: Main process exited, code = killed, status = 11 / SEGV
Sep 04 21:57:15 sd-89425 systemd [1]: urbackupclientbackend.service: Unit entered failed state.
Sep 04 21:57:15 sd-89425 systemd [1]: urbackupclientbackend.service: Failed with result ‘signal’.
Here’s what we do in the /var/log/kern.log:
Sep 4 21:57:15 sd-89425 kernel: [197.881107] file indexing [2739]: segfault at 0 ip 00007f82f5091049 sp 00007f82edff7528 error 6 in libc-2.19.s
o [7f82f4fff000 1a1000 +]
The client stops and can not perform backups.
On the interface:
04/09/17 21:57 DEBUG sd-89425.dedibox.fr: Connecting for filelist (async) …
04/09/17 21:57 DEBUG sd-89425.dedibox.fr: Failed to connect to customer. Retrying in 10s
04/09/17 21:57 ERROR Constructing of filelist of “sd-89425.dedibox.fr” failed: error - Async indexing process not found
04/09/17 21:57 ERROR Backup had an early error. Deleting partial backup.
Can you help me ?
thanks in advance
Kilian
