Should I bother using compressed vhd for my images if I’m using Freenas as my storage with max compression already on the storage?
I did. I’m running the urbackup server in a FreeNAS 9.3 jail. At first, I didn’t use vhdz compressed images, since my main pool is using lz4 compression, but some experimentation showed that vhdz + LZ4 was using less physical blocks than vhd + LZ4.
Not sure I can still claim that compression is warranted, though. Unfortunately, I don’t have the original data. My oldest snapshot still has a mix of vhd and vhdz images, but I don’t see an easy way to determine the uncompressed size of a vhdz for a fair comparison. In that old snapshot, here’s the data on all the full image backups:
PC1/Image_C_150127-0231.vhd 88789440 130464196096 1469.366
PC1/Image_C_150328-0333.vhdz 74827631 76576597863 1023.373
PC1/Image_C_150527-0939.vhdz 75926581 77705955061 1023.435
PC2/Image_C_150127-0243.vhd 96241531 140937616896 1464.416
PC2/Image_C_150328-0344.vhdz 100601205 102981352645 1023.659
PC2/Image_C_150527-0615.vhdz 108005911 110560785757 1023.655
PC3/Image_C_150126-2323.vhd 114874781 191657188352 1668.401
PC3/Image_C_150328-0023.vhdz 108167889 110734719508 1023.730
PC3/Image_C_150527-0025.vhdz 111441920 114087366728 1023.738
The 2nd and 3rd columns are the disk block counts and file sizes (from ‘ls -ls’), and the last column is the file size divided by block count, for file bytes stored per 1K disk block. The large vhdz files are storing just a bit less than 1K file bytes per 1K block, so there’s apparently no extra compression happening there. But notice that for PC1, the 150127 vhd is using about 20% more blocks than the 150328 vhdz. On that machine, I would expect that the actual image sizes of those two backups would be similar, so the vhdz compression did actually have a big benefit. There’s a smaller 6% benefit for the same January-vs-March backups on PC3, but a 5% loss on PC2.
Without determining the actual uncompressed sizes of the vhdz files, I can’t be sure if those size differences are due to better compression of vhdz+lz4 over vhd+lz4, or a result of changing files in those images over the 2 months between them. The fact that the vhdz files are all storing about 1,023 bytes per disk block means that lz4 compression has no benefit over the vhdz compression. But (if I’m right that the January versus March images are roughly the same raw sizes) the block count improvements of vhdz over vhd likely means that the vhdz compression algorithm in urbackup is better than the lz4 one in FreeNAS.
The image compression uses zlib (miniZ actually but the same alogrithm). This compresses better than lzo at greater CPU cost. So if you use zlib on ZFS you should get about the same compression ratio.
I would use the ZFS compression as it makes handling the images easier e.g. if you want to mount one on Windows. And ZFS does not try to recompress it again.
