Just started using Urbackup and I do really like the concept!
Can’t give you a certain way to reproduce this right now but when I make changes in settings via the webinterface it happens quite often that all settings are reset to default.
What can I do?
By the way: I didn’t found a donation button
Cheers!
If you only want to change the settings on the server you can check “Allow client-side changing of settings”. This changes the behaviour a bit.
The settings propagation will get an improvement with 1.5.
To Donate, click the “About UrBackup” on the server login.
