UrBackup Client 2.4.10 (x86/x64) (Vista/7/8.1/10 + Server editions) without tray icon doesn’t work on Hyper-V Server 2012 R2 (“ServerHyperCore”, build 6.3.9600.16497) , throwing error 1067 whenever starting the service. It must be noted that VMs are not the target, but rather the files on hypervisor FS.
Debug log:
2020-11-26 13:19:05: Loaded -fileserv- plugin 2020-11-26 13:19:05: Loaded -fsimageplugin- plugin 2020-11-26 13:19:05: Loaded -cryptoplugin- plugin 2020-11-26 13:19:05: SQLite: recovered 24 frames from WAL file C:\Program Files\UrBackup\urbackup\backup_client.db-wal code: 283 2020-11-26 13:19:05: urbackupserver: Server started up successfully! 2020-11-26 13:19:05: FileSrv: Backup privileges set successfully 2020-11-26 13:19:05: FileSrv: Backup privileges set successfully (SE_SECURITY_NAME) 2020-11-26 13:19:05: FileSrv: Backup privileges set successfully (SE_RESTORE_NAME) 2020-11-26 13:19:05: FileSrv: Server started up successfully 2020-11-26 13:19:05: Started UrBackupClient Backend... 2020-11-26 13:19:05: Filesystem. Vol="\\?\Volume{dc5b81e8-b9bb-11e4-8123-806e6f6e6963}\" Name="зарезервировано системой" Type="ntfs" VPaths=0 Size=366997504 2020-11-26 13:19:05: Bootable flag set for volume 2020-11-26 13:19:05: Found potential candidate: \\?\Volume{dc5b81e8-b9bb-11e4-8123-806e6f6e6963}\ Score: 3 2020-11-26 13:19:05: Filesystem. Vol="\\?\Volume{dc5b81e9-b9bb-11e4-8123-806e6f6e6963}\" Name="" Type="ntfs" VPaths=1 Size=999835037696 2020-11-26 13:19:05: Filesystem is System partition. Skipping... 2020-11-26 13:19:05: Selected volume \\?\Volume{dc5b81e8-b9bb-11e4-8123-806e6f6e6963} 2020-11-26 13:19:05: System dir: C:\Windows 2020-11-26 13:19:05: Volpath: \\.\C: 2020-11-26 13:19:05: Device is not GPT formatted (0) 2020-11-26 13:19:05: Found no EFI System Partition 2020-11-26 13:19:06: ERROR: Internet mode not enabled. Please set "internet_mode_enabled" to "true".
args.txt:
--plugin fileservplugin.dll --plugin fsimageplugin.dll --plugin cryptoplugin.dll --plugin urbackup.dll --no-server --logfile debug.log --loglevel debug --allow_restore default --internet_only_mode true
