Hi, I just installed UrBackup on my Raspberry Pi in my homenetwork and it seems to work great so far. Backing up the Raspberry itself works perfectly. But now I want to Backup a remote Debian Server. The Raspberry is connected to the Server via Wireguard.
The UrBackup Client is installed on the remote server and I can Ping the remote Server (e.g. 10.0.5.1) from my Raspberry (10.0.5.2). When I add the Remote Server in UrBackup webinterface, I enter 10.0.5.1 as a discovery hint. Then the server appears on the status page in a seperate hints section. Sometimes Online says yes and sometimes no. But the server never gets added completely.
Does anyone have an idea what I am doing wrong?
Thanks in advance for your help!
I see you did not get a response on this. Did you find your answer somewhere else?
This is exactly what I was wanting to do.
- Check iperf between urbackup server and server you want to backup.
- Check wan related issues: if you use async connection (if upload speed significantly lower than download) then try to lower mtu (1500 by default) to 1472 for example on your firewall/router.
- Check lan related issues (tcp checksummin, offloading etc.) on network adapters all things that works perfectly on 1gbps and low latency maters when connections established via high latency channels.
- Check firewall security features: filtering settings, logs.
