I’ve just recompiled the urbackupclient following those instructions:
https://www.urbackup.org/client_debian_ubuntu_install.html
Unfortunately it doesn’t work afterwards. I’m getting a segmentation fault. Seems to have todo with libcrypto++. Maybe it’s too new? (I think before version 6 was installed on the system)
[39085.212041] internet client[170941]: segfault at 10 ip 00007fdad5284fe0 sp 00007fdab37fd540 error 4 in libcrypto++.so.8.4.0[7fdad515b000+1e6000]
[39085.212083] Code: c1 49 8b 45 00 8d 71 f8 48 c1 e9 02 4c 8d 79 ff e9 b9 fe ff ff 0f 1f 44 00 00 85 db 74 2c 49 c1 ec 02 74 8e 66 0f 1f 44 00 00 <41> 8b 0c 86 48 8b 5c 24 08 0f c9 89 0c 83 48 83 c0 01 49 39 c4 75
# urbackupclientbackend -v debug -i
2021-01-13 10:34:26: SQLite: recovered 16189 frames from WAL file /usr/local/var/urbackup/backup_client.db-wal code: 283
2021-01-13 10:34:26: urbackupserver: Server started up successfully!
2021-01-13 10:34:26: FileSrv: Server started up successfully
2021-01-13 10:34:26: Started UrBackupClient Backend...
2021-01-13 10:34:26: urbackupserver: No available slots... starting new Worker
2021-01-13 10:34:26: ClientService cmd: STATUS#pw=tMn6dGG0VY91m51fy0KrFLGtVBXZEd
2021-01-13 10:34:27: Looking for old Sessions... 0 sessions
2021-01-13 10:34:27: Final path: /var/www
2021-01-13 10:34:27: Final path: /home/rmm
2021-01-13 10:34:27: Final path: /etc
2021-01-13 10:34:27: Final path: /var/lib/postgresql
2021-01-13 10:34:27: Final path: /var/lib/mysql
2021-01-13 10:34:28: Trying to connect to internet server "urbackup.rmm.li" at port 55417
2021-01-13 10:34:28: Successfully connected.
[1] 171210 segmentation fault urbackupclientbackend -v debug -i
