After some time of operating without trouble, my server hit a segfault yesterday. I was able to manually restart it, and now it seems to be running fine again, but I wanted to report this bug just in case it would be helpful.
Sep 26 11:50:05 backup4 urbackupsrv: WARNING: Block hash wrong. Getting whole block. currpos=769654784
[snip many similar entries]
Sep 26 11:51:23 backup4 urbackupsrv: MD5::finalize: Already finalized this digest!
Sep 26 11:51:23 backup4 urbackupsrv: WARNING: Block hash wrong. Getting whole block. currpos=769654784
Sep 26 11:51:23 backup4 kernel: fbackup load[1240]: segfault at 7fe225e552b8 ip 000000000054f6b5 sp 00007fe225e55260 error 6 in urbackupsrv[400000+63f000]
Sep 26 11:51:24 backup4 systemd: urbackup-server.service: main process exited, code=killed, status=11/SEGV
Sep 26 11:51:24 backup4 systemd: Unit urbackup-server.service entered failed state.
Sep 26 11:51:24 backup4 systemd: urbackup-server.service failed.
This is on CentOS 7, using the Red Hat package downloaded from your site. I’m not aware if it has any other debugging enabled, but I would be happy to check if you could please tell me where to look.
I’ve now put the server into debug logging mode, so hopefully this will catch something interesting next time.
How can I create a core dump? Or would this need to be done at the time of the crash?
Unfortunately I can’t find any info in the server or client logs to indicate if any system was performing a backup during the time when the failure occurred. In the Web UI, I can’t see any backups happening around this time. Can you tell me how I could find this out?
Add LimitCORE=infinity to the [Service] section in the systemd service file. Make sure the file specified by sysctl kernel.core_pattern is writeable by urbackup. Per default it is core in the working directory (/var/urbackup).
