On Debian 10 the client throws a segfault when trying to do a full file backup using dattobd snapshot.
The client is 2.5.16, the server 2.5.22
● urbackupclientbackend.service - UrBackup Client backend
Loaded: loaded (/lib/systemd/system/urbackupclientbackend.service; enabled; v
Active: failed (Result: signal) since Mon 2021-08-23 17:13:55 CEST; 24s ago
Process: 5261 ExecStart=/usr/local/sbin/urbackupclientbackend --config /etc/de
Main PID: 5261 (code=killed, signal=SEGV)
dmesg tells me:
[ 148.725222] file indexing[5266]: segfault at 28 ip 00000000004ab867 sp 00007f22ea7f9730 error 6 in urbackupclientbackend[400000+524000]
I have even switched the client to debug mode:
2021-08-23 17:16:14: Trying to transition /dev/datto0 to snapshot...
2021-08-23 17:16:14: dbdctl transition-to-snapshot '//.datto_3d41c58e-6724-4d47-8981-11c766a08a24_d4bb103327fe602ae20171a6c50dec262c2575d76cb6e76b' 0
2021-08-23 17:16:14: Transitioned /dev/datto0 to snapshot.
2021-08-23 17:16:14: Mounting /dev/mapper/wsnap-d4bb103327fe602ae20171a6c50dec262c2575d76cb6e76b...
2021-08-23 17:16:14: Shadowcopy path: /mnt/urbackup_snaps/d4bb103327fe602ae20171a6c50dec262c2575d76cb6e76b
2021-08-23 17:16:14: Using datto change information from //.datto_3d41c58e-6724-4d47-8981-11c766a08a24_01cc60a567535bbc17bebeed1c7e45dd7a955611380a33d3
2021-08-23 17:16:14: done.
2021-08-23 17:16:14: Zeroing file hash data of volume /...
2021-08-23 17:16:14: Indexing "lib"...
2021-08-23 17:16:14: Hashing file "/mnt/urbackup_snaps/d4bb103327fe602ae20171a6c50dec262c2575d76cb6e76b/var/lib/apt/extended_states"
The same problem occurs on multiple clients with different paths / files (always directly after starting indexing).
I also tried using strace when starting the client.
Using datto change information from //.datto_3d41c58e-6724-4d47-8981-11c766a08a24_d4bb103327fe602ae20171a6c50dec262c2575d76cb6e76b
done.
NULL) = 0
nanosleep({tv_sec=1, tv_nsec=0}, Indexing "lib"...
Hashing file "/mnt/urbackup_snaps/8e88a1b55e429c77eb9aa8e5323cb1142bfbc342ae63e168/var/lib/apt/extended_states"
<unfinished ...>) = ?
+++ killed by SIGSEGV +++
Segmentation fault
The parallel hashing setting (beta) is disabled. Reboot of server does not help.
Thank you for help.
P.S.: Image backup seems to work correctly, full and incremental. It’s just happening on file backup.
