Oleg did the work and created a spec file to build UrBackup RPM packages for RedHat/CentOS/ScientificLinux/Fedora.
Which means we now have this link on the download page:
Thanks goes to Oleg for all the hard work.
Wow, thanks for marking it as a hard work!
Сreation UrBackup repository is a big step forward. Great thanks!
PS This packages built without mail support? How you solved libcurl old version problem in Centos 6 when you build this packages? Will you build Urbackup client packages? As I know building urBackup client is trouble with depending (if you have wxWigets 3.x (or less 2.9 version)), run your configure script is unsuccessfully).
