I’m looking at this as a solution to backup 15 or so road warrior machines (they are sometimes local, mostly external though). As I’m browsing through the documentation I seem to be missing one significant point. Are these clients using the same credentials through the config or can each machine have it’s own credentials for WAN access? The goal is to make sure that if I have someone that’s removed from the org that I don’t have to setup credentials again.
I suspect that I’m just missing the obvious, but can someone point me to the specific documentation on this?
Also is it possible to group machines in the system?
I intend to get a dev environment setup this weekend but I would like to go into the testing armed with as much information as possible.
