Revoked Boot loaders in RUFUS?
I have installed and really like the server side. Backed up a few images. I am creating the Rufus ISO, and I am nervous about being able to boot in an emergency system. I get the following
Warning in RUFUS:
Rufus detected that the ISO you have selected contains a UEFI
bootloader that has been revoked and that will produce a
•Security Violation• screen, when Secure Boot is enabled on a
fully up to date UEFI system.
  • If you obtained this ISO image from a non reputable source,
    you should consider the possibility that it might contain UEFI
    malware and avoid booting from it.
  • If you obtained it from a trusted source, you should try to
    locate a more up to date version, that will not produce this
    warning.
Is there a problem with using it for more modern windows 11 pro machines?
-DM
Put a new image based on Debian Bookworm on the page. This should hopefully fix this issue.
I just turned off Secure boot, thank you for your quick answer and help. I am now testing to do a restore before disaster strikes haha.
