Is it possible to restore more than one volume from an image backup, using the Restore CD?
I have a few computers that are backed up that have a C and D partition on one disk. I’m sure this has been asked before, but could not find a similar post in my search.
Well, this is embarrassing. I had always thought that if you select another volume to restore, and restore it to the same disk as the first… that it would clear all partitions on the disk. That is not the case! Restoring multiple volumes is easy
