Issue1
Node 1 (Server Docker alpine )
Linux node3 4.4.0-173-generic #203-Ubuntu SMP Wed Jan 15 02:55:01 UTC 2020 x86_64 Linux
urbackup = Version - 2.4.10
Node2 (Client Docker alpine)
Node3 (client docker alpine)
urbackup = Linux node3 4.4.0-173-generic #203-Ubuntu SMP Wed Jan 15 02:55:01 UTC 2020 x86_64 Linux
Logs - Restore was inactive for 5min. Timeout. Stopping restore…
i don’t find the conf file in
etc/default/urbackupclient or etc/sysconfig/urbackupclient
Or need to create as below to function restore
/etc/default# cat urbackupclient
# Defaults for urbackup_client initscript
# sourced by /etc/init.d/urbackupclientbackend
# installed at /etc/default/urbackupclient by the maintainer scripts
# This is parsed as a key=value file
#logfile name
LOGFILE="/var/log/urbackupclient.log"
#Either debug,warn,info or error
LOGLEVEL=warn
#Max size of the log file before rotation
#Disable if you are using logrotate for
#more advanced configurations (e.g. with compression)
LOG_ROTATE_FILESIZE=20971520
#Max number of log files during rotation
LOG_ROTATE_NUM=10
#Tmp file directory
DAEMON_TMPDIR="/tmp"
# Valid settings:
# "client-confirms": If you have the GUI component the currently active user
# will need to confirm restores from the web interface.
# If you have no GUI component this will cause restores
# from the server web interface to not work
# "server-confirms": The server will ask the user starting the restore on
# the web interface for confirmation
# "disabled": Restores via web interface are disabled.
# Restores via urbackupclientctl still work
RESTORE="server-confirms"
#If true client will not bind to any external network ports (either true or false)
INTERNET_ONLY=false
while trying to restore. how can i restore my files
Kindly let me know if i need to create a urbackuprestoreclient.service for this.
Issue2
another client i don’t find the restore button on the web ui
Issue3
Till now i am not able to fetch answer from old posts “how can i restore for a specific file in a folder” in Linux
