Hi:
today I want to restore backup. and I terminate it after some time. when I restore, urbackup server is working during clean-up window.
then I want to restore again and got surprised that my recent backup is gone. it seems be cleaned while I use it for restoring. is that possible?
the server logs are below. I interrupt restore at 13:17.
I use full+incremental image to backup servers daily. I was restoring the “fs01” server.
and the whole “full+incremental” image chain was deleted. (although the logs said some delete error, all the files are gone). previous “full+incremental” images are still there.
it seems a serious bug to me, I don’t want recent backup to be clean-up wrongly.
2021-01-26 12:49:11: WARNING: Deleting /backup/urbackup/data/vms/210111-2326_Image_C/Image_C_210111-2326.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:11: WARNING: Deleting /backup/urbackup/data/db03/210112-0025_Image_SYSVOL/Image_SYSVOL_210112-0025.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:11: WARNING: Deleting /backup/urbackup/data/db03/210112-0025_Image_C/Image_C_210112-0025.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:12: WARNING: Deleting /backup/urbackup/data/dms01/210112-0004_Image_SYSVOL/Image_SYSVOL_210112-0004.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:12: WARNING: Deleting /backup/urbackup/data/dms01/210112-0005_Image_ESP/Image_ESP_210112-0005.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:12: WARNING: Deleting /backup/urbackup/data/dms01/210112-0005_Image_C/Image_C_210112-0005.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:12: WARNING: Deleting /backup/urbackup/data/ad02/210111-2334_Image_SYSVOL/Image_SYSVOL_210111-2334.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:12: WARNING: Deleting /backup/urbackup/data/ad02/210111-2334_Image_C/Image_C_210111-2334.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:12: WARNING: Deleting /backup/urbackup/data/HR01/210111-2318_Image_C/Image_C_210111-2318.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:12: ERROR: Cannot delete image because incremental image backup referencing this image cannot be deleted
2021-01-26 12:49:13: WARNING: Deleting /backup/urbackup/data/fs01/210125-2201_Image_SYSVOL/Image_SYSVOL_210125-2201.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:13: WARNING: Deleting /backup/urbackup/data/fs01/210125-2201_Image_C/Image_C_210125-2201.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:13: WARNING: Deleting /backup/urbackup/data/fs01/210124-2200_Image_SYSVOL/Image_SYSVOL_210124-2200.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:13: WARNING: Deleting /backup/urbackup/data/fs01/210124-2200_Image_C/Image_C_210124-2200.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:13: WARNING: Deleting /backup/urbackup/data/fs01/210123-2202_Image_SYSVOL/Image_SYSVOL_210123-2202.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:13: WARNING: Deleting /backup/urbackup/data/fs01/210123-2202_Image_C/Image_C_210123-2202.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:13: WARNING: Deleting /backup/urbackup/data/fs01/210122-2201_Image_SYSVOL/Image_SYSVOL_210122-2201.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:13: WARNING: Deleting /backup/urbackup/data/fs01/210122-2201_Image_C/Image_C_210122-2201.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210121-2204_Image_SYSVOL/Image_SYSVOL_210121-2204.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210121-2204_Image_C/Image_C_210121-2204.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210120-2204_Image_SYSVOL/Image_SYSVOL_210120-2204.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210120-2204_Image_C/Image_C_210120-2204.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210119-2202_Image_SYSVOL/Image_SYSVOL_210119-2202.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210119-2203_Image_C/Image_C_210119-2203.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210118-2200_Image_SYSVOL/Image_SYSVOL_210118-2200.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210118-2200_Image_C/Image_C_210118-2200.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210117-2204_Image_SYSVOL/Image_SYSVOL_210117-2204.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210117-2204_Image_C/Image_C_210117-2204.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210116-2203_Image_SYSVOL/Image_SYSVOL_210116-2203.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210116-2203_Image_C/Image_C_210116-2203.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210115-2203_Image_SYSVOL/Image_SYSVOL_210115-2203.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210115-2203_Image_C/Image_C_210115-2203.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210114-2202_Image_SYSVOL/Image_SYSVOL_210114-2202.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210114-2202_Image_C/Image_C_210114-2202.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210113-2202_Image_SYSVOL/Image_SYSVOL_210113-2202.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210113-2202_Image_C/Image_C_210113-2202.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210112-2203_Image_SYSVOL/Image_SYSVOL_210112-2203.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210112-2203_Image_C/Image_C_210112-2203.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210111-2203_Image_SYSVOL/Image_SYSVOL_210111-2203.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/fs01/210111-2203_Image_C/Image_C_210111-2203.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/tradevan/210110-2352_Image_C/Image_C_210110-2352.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/db03/210112-0033_Image_D/Image_D_210112-0033.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: WARNING: Deleting /backup/urbackup/data/HR01/210111-2325_Image_D/Image_D_210111-2325.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:14: ERROR: Cannot delete image because incremental image backup referencing this image cannot be deleted
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210125-2210_Image_D/Image_D_210125-2210.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210124-2205_Image_D/Image_D_210124-2205.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210123-2208_Image_D/Image_D_210123-2208.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210122-2208_Image_D/Image_D_210122-2208.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210121-2212_Image_D/Image_D_210121-2212.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210120-2210_Image_D/Image_D_210120-2210.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210119-2210_Image_D/Image_D_210119-2210.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210118-2206_Image_D/Image_D_210118-2206.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210117-2209_Image_D/Image_D_210117-2209.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210116-2207_Image_D/Image_D_210116-2207.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210115-2209_Image_D/Image_D_210115-2209.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210114-2207_Image_D/Image_D_210114-2207.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210113-2208_Image_D/Image_D_210113-2208.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210112-2213_Image_D/Image_D_210112-2213.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 12:49:15: WARNING: Deleting /backup/urbackup/data/fs01/210111-2209_Image_D/Image_D_210111-2209.vhd.bitmap failed. No such file or directory (code: 2)
2021-01-26 13:17:00: ERROR: Writing to output pipe failed processMsg-1
