"Restore" option missing
Linux server and client, when browsing file backups from web ui (server) - i don’t have option to restore. I only have option to “Download folder as ZIP”.
I’ve read the manual and it states:
When browsing backups the web interface will show a restore button if the client is online. The restore will ask for user confirmation.
The client is online, when going to “Status” tab, client is listed as online (showing “Yes” in “Online” column for that clients’ row).
And yes, I’ve attempted to download folder as zip and transfer → unzip to destination, however that’s when i realised the zip folder also does not preserve ownerships and permissions of backed up files. So it would be great to add options to download as .tar.gz or include linux permissions and ownership - zip should natively support that.
Without permissions and ownership - restore could be broken this way - since i don’t have visible option to restore.
Server version: 2.5.34
Fixed the doc issue:
To make the button display maybe switch to “server-confirms” in the client.
You can also use the command line to restore as described in the same section in the manual.
